Have you yet checked the basics, like is it getting spark, or does starting fluid get it to pop?
The first day after it wouldn’t start I had the battery tested, it was fine. It had been a while since I changed the spark plugs so I pulled one and it was hammered and wet with fuel. I changed all the plugs and the air filter, then it started right up. Next day I tried to start it and it wouldn’t start.
Quite possibly a bad ignition coil, a cracked distributor cap, or worn rotor. Start by taking the coil wire off the center of the distributor cap and seeing if you get a strong blue spark from it.
I put a new coil and distributor cap in when I changed the plugs, the weird thing to me is the fact that the fuel pump won’t stop running when the key is on. I’ll check to make sure it’s getting spark tomorrow.
