Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
need help
Old Sep 9, 2010 | 12:01 PM
91stealthguy's Avatar
91stealthguy
Default need help
ok i have a 91 RT stealth and the check engine light is on so i want to read the codes, but the thing is i cant find the plug at all does anyone know were to look or have a picture of what it looks like
Old Sep 9, 2010 | 04:09 PM
thestealth's Avatar
thestealth
http://www.stealth316.com/2-diagcodes91-93.htm
Old Sep 10, 2010 | 01:12 PM
91stealthguy
what about the key trick. like turn the key on 3 times fast and count the times the check engine light flashes
Old Sep 10, 2010 | 01:15 PM
thestealth's Avatar
thestealth
That doesn't work on these cars.
Old Sep 13, 2010 | 11:45 PM
91stealthguy
ok so whats the best way to check them cause i dont have an old school volt meter
Old Sep 14, 2010 | 08:25 AM
thestealth's Avatar
thestealth
You can pick a cheap one up at Home Depot for <$10. I tried with a digital volt/ohm meter and it does not work, it's got to be an analog meter.
Old Sep 15, 2010 | 04:47 PM
91stealthguy
ok cause the guy i got the car from said the TPS was bad but i pulled it off and used a ohm meter and it seemed to be working just fine but now im thinking it could be a dirty crank sensor or something
Old Sep 15, 2010 | 09:17 PM
thestealth's Avatar
thestealth
If you get an analog meter and do the test as outlined on stealth316 it will tell you exactly what the problem is. A meter is cheap...and crank angle sensor is not. Find out what is causing the CEL, then go from there. If you are unwilling to do at least that, well, good luck then.
Old Sep 16, 2010 | 11:58 AM
91stealthguy
ya i need to go get one but i have to frive almost a hour to get to home depot but when im able to get down there i will get one and see what it says. im hoping something cheap and easy
Old Sep 16, 2010 | 12:22 PM
thestealth's Avatar
thestealth
what are the symptoms? Poor running, poor fuel economy? Won't start?
WalMart would probably have a cheap analog meter...hell, a test light might work, but I've never tried it.
