EFI/Carb swap Club
Thanks, It has a 383(30 over) forged 10 to ones, edelbrock intake, modded spread bore holley, headers bla bla bla. It was in my charger originally. The six pack efi has progressive throttle linkage. From the videos i seen FAST efi is what most are using. Sounds like the Dominator may fix your issues. That sucks having the dyno that far away. Report back when you get it installed.
http://www.fbthrottlebodies.com/products.htm
I'll let you know
FAST Man EFI Mopar 508" EFI 6 Pack - YouTube
F&B Performance 426 Hemi six pack EFI 2 - YouTube
I thought about it for one of my projects but that's a long way off. To get an accurate reading for both fuel injection an ignition you need a crank sensor and a cam sensor. At least that's the way its done on modern vehicles. It looks like the FAST system is just for fuel. Not sure about what the Holley dominator EFI either. I haven't schooled myself about the all the different systems that are out there. Why i mentioned the megasquirt controller is because i seen some people run the second gen ram trucks with it(and others) with a turbo(or two) and they need a crank and cam sensor to work both fuel and ignition if you remove the original controller(PCM). It's not self tuning but once it gets dialed in it should work perfect. I would think using one controller to do both would be better. With the the separate controllers one doesn't know what the other is doing. Well at least that's my theory.
Thanks for the interest. What kind of Dodge do you have?
Thank you very much! It’s funny you should ask about the electronics. In 2016 I was waiting to attend the Holley training, which was awesome. In 2017, some friends wanted to do Power Tour again, so I didn’t want to have the car down and miss it. Here it’s 2018, and yes, just a week ago or so I started pulling the old harness out. The swap obviously isn’t done, but I have started.
I drive a 98 Dodge Ram 2500 4X4 with the 8.0 V-10. Pass anything but a gas station.
Okay, I will try to keep you posted. I will also give you some feedback, though from everything I have seen and heard, I anticipate it being a huge improvement.
