98Ram 1500 turns but won't start.
Old 12-11-2017, 01:06 PM
Stacy Wright's Avatar
Stacy Wright
Stacy Wright is offline
Default 98Ram 1500 turns but won't start.
I stopped my truck in a parking lot abruptly and it died it will not restart. All the gauges go up and down while making a clicking grinding noises. there is a single tone also sounding somewhere under the dash. Even the tones that normally sound when putting the key in are not working all the time if I move the shifter up and down once in awhile I will hear a normal tone. I also do not here the usual energizing noise I guess it is of the fuel pump when the key is put in and turned but I'm not sure if that's due to something else being out. I can pull a couple fuses from under the hood and the tone that I can barely hear from under the hood stops. Any help with this issue would be greatly appreciated I have no idea what to do. this is never happened before
Old 12-11-2017, 01:23 PM
HeyYou is online now
Is the starter motor actually turning the engine?
Welcome to DF!
Old 12-11-2017, 01:57 PM
Torxhead's Avatar
Torxhead
Torxhead is offline
They battery and its connections are the usual suspects and check for corrosion.
Old 12-11-2017, 04:57 PM
Stacy Wright
Welcome to DF!
Yes the engine is turning.
and like I said, when I release the key all the gauges slowly go down and there is a beep under the dash. Then they jurk back up and slowly go down again. There is also a continuus tone under the dash but it's very low, and van be heard under the hood and barely from under the truck.
Old 12-11-2017, 05:50 PM
Does the engine turn over normally? Or is it really slow? Low batteries can create some rather intriguing symptoms.....
Old 12-12-2017, 11:08 PM
Stacy Wright
It did before I killed the battery trying different things.
Old 12-12-2017, 11:10 PM
Stacy Wright
even when being jumped it don't start.
Old 12-13-2017, 12:05 PM
So what's missing? Spark, or fuel. Easy to check for spark..... see if it's there.
Quick Reply: 98Ram 1500 turns but won't start.
