Sqealing rear brakes while driving
Old 10-19-2018, 09:03 PM
1SaltyGreenBean's Avatar
1SaltyGreenBean
1SaltyGreenBean is offline
Default Sqealing rear brakes while driving
Ok. I just replaced my rear wheel cylinders, brake shoes and all new hardware. Cleaned everything. Lubed up the friction points. I did not replace the drums. And I did not have it checked for the maximum wear limit. I have some tools but not an 11 to 12 inch mic. When driving, especially by a fence, wall, curb ect....., I hear a squealing noise on the drivers rear. when I hit the brakes the noise stops. ???????? Possible bad new spring? It all looked and went together like it should. So I pulled it off again tonight. This will be my fourth try. I can not figure this out. I said screw it and came in to post this thread. Realizing I needed help again. Thanks for any advise!!
Old 10-19-2018, 11:32 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
Did you break in the new pads? When I worked at the Dodge garage they said about doing 2 medium stops from 35 then 2 hard stops at about 40-50. My rear brakes did that until I did that then it quite
Old 10-20-2018, 08:03 AM
1SaltyGreenBean
Yes. I did perform some break in stops. Even a couple in reverse. While looking at them this morning they appear to look real shiny already ( the shoe surface). like they are glazed over already. Now I'm thinking cheap *** break shoes. Problem is with that is these are the same brand I have used since buying the truck new. The adjuster was screwed all the way in so the drums go off and on very easy. I also just noticed that the adjuster stop is not engaging with the teeth on the adjuster. Almost like the e brake cable that runs from the adjuster stop to the top post is too long. Still confused. Thanks again.
Old 10-20-2018, 08:35 AM
HeyYou is online now
Received 3,208 Likes on 2,959 Posts
Can you post a pic of what things look like?
Old 10-20-2018, 09:08 AM
fj5gtx's Avatar
fj5gtx
fj5gtx is offline
Adjuster all the way in, sounds unusual. You need to adjust your shoes so that they are just slightly skimming the drum when you spin it.
Old 10-20-2018, 02:01 PM
racefan41's Avatar
racefan41
racefan41 is offline
When you cleaned the rotors, did you use and light sandpaper/steel wool or something or something like that to get the glaze off the surface? Is the squeal pretty constant or does it sound like its hitting at a high spot on the rotor?
Old 10-20-2018, 03:07 PM
fj5gtx's Avatar
fj5gtx
fj5gtx is offline
He is working on his rear drum brakes...
Old 10-21-2018, 11:48 AM
1SaltyGreenBean
Default Some pics
Old 10-21-2018, 11:49 AM
Anywhere nearby you could get those turned?
Old 10-21-2018, 11:55 AM
1SaltyGreenBean
Trying that again. Can't seem to post only one at a time.
Quick Reply: Sqealing rear brakes while driving
