2000 Dakota with posible computer problems
My 2000 Dodge Dakota started stalling over the last few months. The last time it stalled for me, it took approximately 15 minutes before it would start again. While trying to start it, I notice the odometer changed from a number to a phrase "No Bus". I'm assuming that is telling me it cant find the computer.
Any thoughts?
Bill
Any thoughts?
Bill
I have the 4.7 ltr
Another update … the problem gets worse as the engine runs longer (gets hotter) Stop and go traffic for 30+ minutes , the problem will surface quicker....
another issue that I'm seeing is … the dash board stops working. the gauges stop reading actual readings when this problem occurs. When I turn the key off and on nothing changes. Once I see the gauges working, I know the truck will start.
It takes approx. 15 minutes of rest .. then the truck will start. the other symptom is … this does not always happen at a stop … the last trip today, the engine cut off at 45 miles an hour.
Being thermal related, could be a couple things. Crank/cam sensor getting hot and shorting internally, or PCM getting hot and the circuit board warping/loosing connection inside.
This has floated around the internet over he years and been verified a few times as working:
Anyone with a Chrysler/Dodge/Ram/Jeep with the jtec style computer, there is a simple solution to the random rough idle and stalling issues. Remove the left torx screw on the PCM computer, add two washers and then replace the screw. Can do the same with the other side, but do them one at a time. The screw seems to be just long enough to eventually ground out a component inside the computer and cause the engine to stall out. Didn't believe it myself, but when I pressed on the screw there in the front the engine died and backing the screw out fixed the issue. On warm days or once the engine was warmed up, the thermal expansion must have been just enough to momentarily ground the component.
wow! very interesting .
What I don't understand … is why does an engineer care if the crank shaft is not turning .. why shut off the engine if the sensor is giving back false information. turn the engine light on … don't turn off the engine....
what happened to the old school of no computers.
