Vacuum line for 4WD actuator 1990 1 Gen
Old 04-17-2024 | 11:09 AM
Mprevade's Avatar
Mprevade
Default Vacuum line for 4WD actuator 1990 1 Gen
I have had this truck for a number of years and never really needed or paid attention to the four-wheel-drive mode. I do not believe I have proper vacuum requirements when in 2 WD and 4WD. How does the vacuum direction change to the actuator is my question? When in 2 WD the outside port should be under vacuum, and when in 4 WD the inside port should be under vacuum is my understanding. What mechanism changes that direction when you physically shift into four-wheel-drive? Is there a directional switch/valve that I’m missing?
Old 04-17-2024 | 01:40 PM
u2slow's Avatar
u2slow
This thread discusses the vacuum switch on the tcase.
https://www.ramchargercentral.com/th...delete.327612/
Old 04-17-2024 | 09:18 PM
Mprevade's Avatar
Mprevade
Hey all, figured out with a little more following the vacuum lines. Found the transfer case switch and replaced it and we are back in order. I added these photos for reference purposes, you can see in the one photo that the spring loaded button is stuck and therefore rendering the switch inactive. It was a chore to change, but did the trick. Thanks for the help.
Old Today | 11:32 AM
98dodgeramjames's Avatar
98dodgeramjames
Can I use a crescent wrench to get that switch off
Old Today | 11:33 AM
98dodgeramjames
What's this line for that's right above the switch
Old Today | 11:58 AM
I think that one is just the t-case vent..... just run it up somewhere above the water line. (how deep do you wanna go?)
Old Today | 12:29 PM
98dodgeramjames
So it's just a breather basically
Old Today | 01:17 PM
Correct.
Old Today | 01:30 PM
98dodgeramjames
Correct.
Thanks man you been a lot of help to me
Quick Reply: Vacuum line for 4WD actuator 1990 1 Gen
