Mess -o- troubles....
Old Today, 10:02 AM
Really Old Man's Avatar
Really Old Man
Really Old Man is offline
Exclamation Mess -o- troubles....
Hey guy's
If you remember, I recently replaced head gasket (2nd time) and I'm wondering,
that since I also replaced the gauges with an aftermarket set Incl sensors, leaving the original plugs disconnected, and it now won't fire up. Battery spins starter fine.
Did I screw up something needed by the computer? Water temp and Oil pressure gauges replaced, (because of erratic operation) wired to sensors and 12V power. OEM plugs left hanging.
The only indication is from the water temp which registers 180 deg, the instant I turn the key first thing in the AM. Can't tell anything yet about oil pres., as engine won't start. I'm hoping the Water temp issue is simply a matter of resistance and I'll have to add a resistor to the circuit to lower the gauge reading...
I don't have any means of transportation without this truck. I'm in the boonies! with cataracts, and having eye surgery scheduled this week.
That's the mess -o- trouble
Thanks All!!
Old Today, 10:06 AM
dodgetruck2's Avatar
dodgetruck2
dodgetruck2 is offline
The computer will fuel/adjust timing based off coolant temp. If its unhooked that would mess with proper operation but I don't think it would cause a no start.
What is the truck information. Looks like a late 90s Dakota, probably a 4.7?
Old Today, 10:14 AM
Really Old Man
The truck, is a 2000 sport with the 3.9L magnum.
Old Today, 10:44 AM
HeyYou is online now
Received 3,363 Likes on 3,105 Posts
Actually, yeah, it would..... With an open circuit, the PCM sees -40 degrees C, and positively DUMPS fuel trying to get a burnable mixture. That will flood the engine in short order, and cause the no start.
Old Today, 11:19 AM
Really Old Man
Thanks Admin....
So, can I just jumper the plugs , or do they need to "see" a specific resistance?
if so do you have that info?
Old Today, 11:37 AM
Originally Posted by Really Old Man
Thanks Admin....
You WANT the PCM to see an accurate temp reading, otherwise, the engine will only run 'properly' in a very limited temp range..... You gauge in the dash also gets its clue from the PCM, (2000 model year? Right??) if it read erratic, probably be a good idea to plug in with a scanner, and see what the PCM is actually seeing.
Old Today, 11:38 AM
Really Old Man
Yeah, I don't have that ability No other transport available If I can just get it to run, no matter how poorly, I can then drive it to a shop.
Old Today, 12:01 PM
Plug in the original temp sensor...... Might wanna pull a plug or two, and see if they are wet....
Quick Reply: Mess -o- troubles....
