HID Special $60.00 Shipped for Dodgeforum members
#981
Hi,
I know this has probably been answered here a hundred times but i looked and couldnt find it. I have a 2009 ram 1500 slt with dual headlights. What bulbs will i need to get and what others. I think it is the h13 set if i am correct. And will i need to get a relay harness or cancelers? Also is there anything special that i will need to do. I have hooked this up before on a 2004 jeep.
Thanks for the help guys.
#982
Hi dalbertson,
Yes you will need the H13 for your 09 Ram with dual headlights. As long as you specify your vehicle info on your order, we will include cancellor and relay for your truck, as they are required. Thanks!
#986
I own a 2008 Ram and was wondering what is needed and how much? What is a good choice to buy-5000 or 8000. I also have DRL in Canada should they be turned off? Thanks
#987
Hi, you will need the relay and capacitors. As far as color temperature is concerned, it's mainly a personal perference. I'd go for 5000k or 6000k for brightest, while 8000k will give you more blue, if you are into that look. Disabling DRL is recommended, and in some cases, required. Thanks.
