My Official Solid Axle Swap Thread (The Discussion Thread)
Old Mar 9, 2010 | 04:58 PM
  #101
95_318SLT's Avatar
95_318SLT
Picked up my tires today. Now I need to decide how to clearance them for up-flex...
I'm thinking either bump stops to limit up-flex, or reshape the wheel wells!!
Old Mar 9, 2010 | 06:55 PM
  #102
Crazy4x4RT's Avatar
Crazy4x4RT
Sick!!!!
Old Mar 9, 2010 | 07:18 PM
  #103
Az93DKota's Avatar
Az93DKota
Old Mar 14, 2010 | 06:22 PM
  #104
95_318SLT's Avatar
95_318SLT
Got the rear axle mounting hardware the other day. Tell me these peices ain't heavy duty!!!!
Old Mar 14, 2010 | 07:03 PM
  #105
Crazy4x4RT's Avatar
Crazy4x4RT
WEAK!! Is that what you wanted to hear? JK
Sweet! It's going to be BAD A$$!
Don't tell me the tear down started. I see the parts on the floor!
Old Mar 14, 2010 | 07:30 PM
  #106
95_318SLT's Avatar
95_318SLT
Oh yeah, teardown has started. Ready to start cutting tomorrow! That is going to be the most nerve-racking part of the whole project!
Also, I was curious where the truck would sit, so I put a tire under the front wheel well. I also grabbed my coil springs for a reference. The coil springs I have have a 300 pound per inch rate, and I estimate there is 1200 pounds on each front spring, so they will sit down about 4 inches with weight on them. The springs reached down to the tire bead when I held them in their approximate place, minus 4 inches they'll sit down, leaves another 4.5 inches to put the springs on the axle's centerline, but the coil buckets are above the axle's centerline So.... that all means the truck is going to sit about 5-6 inches higher than it sits in this picture...
Old Mar 14, 2010 | 09:00 PM
  #107
LO 619's Avatar
LO 619
http://www.offroad-engineering.com/index.html
They have really good stuff, but it's not cheap.
Old Mar 14, 2010 | 09:13 PM
  #108
LO 619's Avatar
LO 619
That's bada$$, dude... can't wait to see pics!
Old Mar 15, 2010 | 05:24 PM
  #109
Crazy4x4RT's Avatar
Crazy4x4RT
Point of no return!
Old Mar 15, 2010 | 07:22 PM
  #110
95_318SLT's Avatar
95_318SLT
Originally Posted by Crazy4x4RT
Point of no return!
Thats right!! There is no welding those mounts back on now. Next time that truck sees the road will have to be with a solid axle under it!
