Only have 2nd and 3rd gears- limp mode
I have a 2000 Dodge Durango SLT. Back in April I had the input sensor replaced. At that time I couldn't go over 40 without it seeming like my transmission was shot. Once sensor was replaced had no problems. Now the code showing is for the output sensor. It only has 2nd and 3rd gears. I was told that means it is in limp mode.
I also was told that I have a linkage out. I was told I have been driving in 4wd and it screwed up my transmission.
My problem is the person who told me this has screwed me before on transmissions. My 4wd light has never been on. I have been told by another garage that it could just be the output sensor and fix the linkage problem. I am just wondering if anyone else has had this issue and what the solution was.
ALWAYS get a second (or third, or fourth) opinion when it involves thousands of dollars in repairs.
And if the guy who told you it screwed up your tranny has screwed you before....why are you even talking to him?? I would NEVER give a guy a second chance to bend me over. Not only that, I'd make sure everyone knew about the first screwing he gave you.
I'm not sure how being in 4WD for an extended period would ruin your tranny. Transfer case, or front bearings, joints, etc. maybe, if it was in for a LONG time...but I don't see what it could've done to your transmission. Everything inside it does exactly the same thing in 4WD as it does in 2WD, so far as I know (still don't know everything about these Durangos). The transfer case, front shaft and front diff do the "4WD stuff"...tranny has nothing to do with it, other than having to work a little harder, and even that added stress shouldn't be enough to do any damage to ANYTHING other than your clutch pack, which should be negligible. The fact that it still drives down the road at all tells me your clutches and the other internal workings are probably OK, and that it's some sort of logic problem (sensor, tranny ECM, whatever).
Like I said...replace the sensor and check the linkage and see what happens. I'd bet the guy who told you your tranny was bad just remembers getting to hose you once before and expects to get another easy payday from you.
The person who screwed me on my last trans is a family member who is actually a good mechanic. Problem is if your vehicle needs fixed when he is in need of money. If so, then you will have a bigger problem than you started with. I originally was having him help with the output sensor but then he said my tranny is shot. But the excuse was that I had been driving in strictly 4wd for too long. That didn't sit well with me, considering these things are built for just that.
I have taken it to one other shop already, waiting to hear from them and will go from there. I do know that if it is the trans it will go to someone different. I just thought I would give it a chance to see if anyone else had a similar problem and what the solution was. The sensor is only $22 and I have been told its not a hard job to change. No clue about the linkage.
I am fairly sure that if your transfer case was in 4WD you would have a light on your dashboard (either amber 4WD Part Time of green 4wd Full Time) should (someone correct me if i'm wrong) illuminate regardless of your selector linkage being broken. Once again 4WD full time is ok on the road. If 4WD part time was engaged you should be able to feel the steering wheel resisting turning when driving.
Hope this helps
Last edited by that_guy; 10-31-2011 at 09:43 PM. Reason: made a mistake trying to type quickly
ok im going to clear up some inaccuracies in here
1) driving in 4wd PT on dry pavement will do damage to the t-case, and maybe the front driveline, NOTHING MORE!!!!!!!!!!!!
2) if there is a 2wd option on the t-case that is where it should be driven under normal conditions, 4wdFT is there, but using it all the time is a waste of gas, and will over time (a very large period of time of course) wear out the case, driving this way in the rain if you have problems accelerating in 2wd is fine, but dont leave it there if you dont need the extra traction.
all that said
3) change the output speed sensor, its a cheap part, and easy to access and will very likely fix your problem (no promises, but i would very much change it first if it was me)
Trending Topics
Here is the information I know about my vehicle. It is a V8 4.7L. Trans is 45RFE. Transfer case has 4lo, n 2wd, 4hi.
I have taken it to a shop and they ran diagnostic tests yesterday. Im suppose to get a call today to see what they came up with but he told me he really didn't think it was the tranny. Atleast not to the point of replacing the entire thing.
I wanted to get some opinions so I know for sure I am not being screwed. I don't know a lot about vehicles and cant afford to put a lot of money out on something that isn't actually the problem.
