Oil pressure
Oil pressure
So i changed my oil yesterday and never started the truck, I started on figuring out the cruise control just finished that and went to start it to warm up and NO OIL PRESSURE great that's want blow the motor in my 02. I have a few things I'm goin to check does anyone have any other suggestions
The sender is part # 5149097AA. It sits right above the oil filter, down under. You can remove it and thread in an oil pressure gauge to check the pressure. You can rent the pressure gauge for free at most auto parts. Of course, you gotta get it running to get pressure first. You might need to rent a fuel pressure tester too.
So I just replaced the oil pressure switch and it's still showing no oil pressure. Ibe tested the wires but didnt get a really good reading, so im got to retest the wires ( with a power prob ) and use my scanner to check oil pressure. If anyone knows something I don't plz lmk
Have you been running synthetic or conventional oil?
Trending Topics
So you got it running and still nothing? The engine would be making a racket with zero oil pressure and I don't mean just the lifters. I would check oil pressure with a manual gauge. You can also run some 5 min motor flush, like Motor Medic. If it's clogged up it might help, otherwise you will have to drop the oil pan.
Idk of it helps but my scanner reads the same if the trucks on or off
