What/How to clean my pistons
Old 03-20-2005, 11:53 PM
NYG's Avatar
NYG
NYG is offline
Default What/How to clean my pistons
I just broke my engine down to rebuild it - I am trying to re-use 3 of the 4 pistons from my old block - the 1st piston went thru the block!
In the 1st pic - on the left is one of my original piston - the one on the right is a brand new piston - what can I use to clean up the old piston
Should I be concern about the build up on the old piston - all 3 of my pistons are gooked up with some sort of burnt on crap!
The 2nd pic has the Old piston on top and the new one on bottom.
Any input would be greatly appreciated
Greg
[IMG]local://upfiles/4417/92220B11340F4C889CB58476855CFBCC.jpg[/IMG]
[IMG]local://upfiles/4417/B333CBC4C9A84ACF9B3E6722CBC63962.jpg[/IMG]
Old 03-20-2005, 11:55 PM
NYG's Avatar
NYG
NYG is offline
Default RE: What/How to clean my pistons
Just in case you are curious about piston number one - here is a pic of it - or at least whats left it!
[IMG]local://upfiles/4417/C1BD4FF0D8574E7287C649A2F181F1ED.jpg[/IMG]
and here is the rest of Piston #1
https://dodgeforum.com/m_173130/tm.htm
Old 03-21-2005, 12:30 AM
casper's Avatar
casper
casper is offline
Its just carbon. A wire brush will take it off.
Old 03-21-2005, 12:38 AM
RayDog26's Avatar
RayDog26
RayDog26 is offline
they sell part cleaner at the store that takes off carbon build up.. just make sure it is ok to use on pistons..... that will make it easier with the wire brush
and DAMN.. that piston is f**ked up lol
Old 03-21-2005, 12:41 AM
casper's Avatar
casper
casper is offline
It should come off easy with a wire brush. The cleaner will help though. It won't damage the pistons they are metal.
Old 03-21-2005, 12:48 AM
NYG's Avatar
NYG
NYG is offline
When you say parts cleaner - are you refering to stuff like Brake Parts Cleaner or Mineral Spirits?? Or do you recommend something else?
Thanks for the feedback Casper and RayDog26!
I have to agree RayDog26 - that piston is f**cked up! I can't complian - I had over 18 races on that engine and I was running down the 1st place car - I pulled up right behind them coming out of Turn 3 at AMS - just as I stared to pull along side - the Rod went right thru my block!
Greg
Old 03-21-2005, 01:10 AM
RayDog26's Avatar
RayDog26
RayDog26 is offline
http://www.partsamerica.com/ProductD...ber=0362005RND
some thing like that would work but you can prolly get a smaller can since your only doing pistons unless u wanna do all the other parts.
Old 03-21-2005, 01:37 AM
casper's Avatar
casper
casper is offline
That will work, they have smaller spray cans too though.
Old 03-21-2005, 10:10 AM
NYG's Avatar
NYG
NYG is offline
Thanks for the link and the info Casper & Raydog26 - I will have to pick some up after work today!
Thanks
Greg
Old 03-21-2005, 04:48 PM
bsiebert's Avatar
bsiebert
bsiebert is offline
I found that carb cleaner (not the spray can either) works excellent for motor parts, as long as there is no plastic or really soft thin metal. The stuff eats anything. Juts give it a couple hour soak, and most parts come out perfectly clean.
Quick Reply: What/How to clean my pistons
