SRT-4 Swap Progress
Old 03-07-2007, 10:09 PM
NEONRT98's Avatar
NEONRT98
NEONRT98 is offline
Default RE: SRT-4 Swap Progress- Update
Alright, so I have run into a problem. I have successfully got the K-frame mounted up! Horray!... Now I have run into a problem! I went to put the wheel spindle/hub on the balljoint and install the struts (SRT-4 struts and spindle/hub) and it seems like the strut is too long, and when the strut is connected to the strut tower, it is off with the spindle/hub!... Any thoughts?
  #32
Old 03-08-2007, 02:06 AM
das2123's Avatar
das2123
das2123 is offline
Are you using the SRT-4 struts?
  #33
Old 03-08-2007, 02:41 AM
NEONRT98's Avatar
NEONRT98
NEONRT98 is offline
Yeah, where the knuckle and the strut connect is different between the 1st gen an SRT-4. THe SRT-4 has a thicker knuckle, so the strut's brace is wider, where as the 1st gen is thinner, so the brace is thinner. I cant mix and match the two...
  #34
Old 03-08-2007, 02:49 AM
das2123's Avatar
das2123
das2123 is offline
I figured that, but was just wondering.
  #35
Old 03-08-2007, 02:55 AM
NEONRT98's Avatar
NEONRT98
NEONRT98 is offline
Heh, no suggestions then..? Bah! I think I might just take out the knuckle and strut, connect them, then connect it to the A-arm... if that doesnt work, I am clueless...It's got to go on there though! When I got the other car, it was on there like that! I will get some pics posted as soon as I find out where the camera is!
  #36
Old 03-08-2007, 03:00 AM
das2123's Avatar
das2123
das2123 is offline
I'll see if I can find you some info, but won't be until tomorrow though.
  #37
Old 03-08-2007, 03:16 AM
NEONRT98's Avatar
NEONRT98
NEONRT98 is offline
Aight man, sweet, thanks! I've looked around, looks like not many people swap the K-frame with everything....
  #38
Old 03-08-2007, 11:05 PM
NEONRT98's Avatar
NEONRT98
NEONRT98 is offline
Hey DAS, find anything useful?
  #39
Old 03-09-2007, 12:13 AM
das2123's Avatar
das2123
das2123 is offline
ORIGINAL: NEONRT98
Not yet, but I will definitely post when I do.
  #40
Old 03-10-2007, 09:15 PM
NEONRT98's Avatar
NEONRT98
NEONRT98 is offline
Alright, I got the struts/knuckles and all that stuff done! Now I have a small problem. Since the transmission is a hydralic tranny, I need a different clutch pedal... Well, I bought a set of SRT-4 pedals off Ebay... and the damn things wont go in where they are supposed to! Did I buy the wrong ones? Is there a difference between the PT and SRT-4 MTX pedals?
Quick Reply: SRT-4 Swap Progress
