Parking Brake Issues
Old Sep 26, 2020 | 10:39 AM
James Jamie Soule's Avatar
James Jamie Soule
Default Parking Brake Issues
I had a lot of slack in my new to me 1983 W250 parking brake cables. My indie shop removed drums and found that the brake shoes were new as reported by seller but drums were old and one cable on one side was not hooked to parking brake hardware fitting behind drum. That being said, indie mechanic adjusted slack and reports normal cable pressure "feel" when applying parking brake but parking brake not really gripping drums to avoid truck rolling away. I have not checked with indie, but I have a feeling that he did not first adjust shoes outward until drums were locked and then backed off and then adjust cable. I have a hard time believing that he would not first do this, but then again I am often surprised when a pro overlooks a basic first step. Can anyone (giving the indie the benefit of a doubt) come up with another reason other than the above that my parking brake cannot be corrected correctly with full shoe contact with drums? I am going to call the seller to find out who did the rear brakes - perhaps brake shop messed up and did not install springs and hardware correctly? I would think the indie who just pulled drums would have noted this if this were this case -he is a 60 year old plus guy, very familiar with older trucks. Thoughts? Is this a known first gen issue? Thanks!
Old Sep 26, 2020 | 11:58 AM
How is your brake pedal? No excessive travel before the brakes actually start doing something? Are the rear brakes working?
Think I might check the adjustment, and then perhaps re-adjust the e-brake.
Old Sep 26, 2020 | 12:53 PM
James Jamie Soule
I would not describe a lowish pedal situation with my truck but I am willing to bet at this point the shoes have not been adjusted outward manually via the backplate slot/adjuster wheel. If this is the case, then the pro clearly does not know what he is doing - and I do feel that if so, I cannot get good rear braking contact hydraulically or mechanically when deploying parking brake. Generally speaking, this is why I prefer to do my own work versus paying for poor work. I am up to my ears in carpentry work at this time hence taking it to a shop.
Old Sep 26, 2020 | 01:00 PM
It's time, or money, you never have both at the same time.
Are the rear adjusters even free? Way too many times I have a seen lotsa new parts under the drum, but, a seized adjuster.....
Old Sep 26, 2020 | 01:40 PM
James Jamie Soule
Thats a good call, if the tech had the drums pulled and did not take the time to clean up/unseize adjusters = waste of my time and money. Those self adjusters over time get pretty funky and often do not work as you noted.
Old Sep 27, 2020 | 11:15 AM
Xombi's Avatar
Xombi
New adjusters and adjuster cables come as a kit. Often the notches on the adjusters are worn so badly that the pawl cannot engage. Rear parking brake cables should be replaced in pairs, and check the cable running to the front as well. All of mine were toast.
Old Sep 27, 2020 | 02:49 PM
James Jamie Soule
Thanks Xombi! Btw, is there a good site for cable/adjuster kit and other for first gen trucks?
Old Sep 27, 2020 | 05:07 PM
Xombi's Avatar
Xombi
I got all of my brake stuff from Federated. It's a small chain that largely deals with pros. Sometimes stuff has been swapped out and it is nice to be able to go to a knowledgeable counterman and match your stuff up. If it is weird stuff the internet is too hit and miss, the money saved is time lost when you have to reorder. Always use the same counter person, as these folks are commissioned pros. Bringing coffee and doughnuts is helpful also. Give them the respect deserved.
They do make fun of the fact that I am wasting my time on a rusty dodge. But they know my name and face and will order for me. It is helpful to have OEM numbers to make their cross easier.
Do the research and make it easy for all. The Laurel Md, store, managed by Steve, has found lots of stuff for the 30 year old plus oddball cars that attract me.
Next up is my 87 Honda Wagovan. 4wd 6spd manual with a granny.
Old Sep 12, 2025 | 12:21 PM
ElkCon's Avatar
ElkCon
i think when both lights are on - that means the PCM and or ABS computer isnt working properly...or there is a mismatch
I have the wrong VIN inside the PCM I pulled from the junkyard.
No codes- getting 14MPG - best ever - it isnt the pcm...its a VIN mismatch error - both lights pop on 60 seconds after start...just like yours
so...maybe I can look in the service manual when I dig it out for you if you want
Old Sep 12, 2025 | 06:09 PM
1st gen ram doesn't care about the VIN. And the ABS lite will come on if there is a brake system issue as well. It may are may not be ABS related.....
