Transmissions
Old Nov 3, 2011 | 09:24 PM
Brian_'s Avatar
Brian_
Originally Posted by spshultz
I've got a 5-speed and just today I heard for the first time a very light "clock, clock, clock" sound. At first I thought it was a rod but it sounded like it's coming from the back of the engine. I pushed the clutch pedal in and the noise stopped. I let the clutch back out and the sound came back. Would that be the throwout bearing that's making the noise?
woah im having this same issue. when i was driving on the highway today i was in 5th and thought the same thing, so i pushed in my clutch and it came back. at first i thought it was my radio, but its definitely something in the tranny or engine? my other question how do i change my tranny fluid & filter, yes i know stupid question but it had to be asked?
Old Nov 4, 2011 | 10:43 AM
spshultz's Avatar
spshultz
Brian,
There's no filter on the 5-speed. You just need to drain and refill with the right oil (I used Pennzoil Synchromesh). There is a large drain plug on the bottom of the trans. And then the fill plug is on the passenger side of the trans.
All you have to do is drain it and then refill it up to the bottom edge of the fill hole (or you can remove your shifter and fill it that way) while on a level surface. It will take about 4.8 pints if it's completely empty. Anyway, there's not much to it.
Old Nov 4, 2011 | 07:30 PM
Brian_'s Avatar
Brian_
thanks a lot shultz! i still want to know what this issue is that you and i are having with the clock clock noise.
edit : i have ax-15 tranny
Old Nov 5, 2011 | 01:02 AM
master tech's Avatar
master tech
Site Moderator & Tech
Brian
The problem you are having with the shifting, could be cause by either bent shift rods or synchro's.
Old Nov 5, 2011 | 01:03 AM
master tech
spshultz
The knocking sound maybe from either the input shaft bearing or bad throw out bearing.
Old Nov 5, 2011 | 01:07 AM
master tech
rakaric You may have a damage bore that the accumlator and seal that allow the transmission to shift into 4th gear. I would have someone hook up a drb3 and perform a clutch test on the transmission.
Old Nov 5, 2011 | 01:08 AM
master tech
thewade44
I would find a shop that has a power flusher and watch them as they do the flush.
Old Nov 5, 2011 | 01:11 AM
master tech
dodgeramguy85
Replace the governor and transducer. The governor is hunting to upshift.
Old Nov 5, 2011 | 03:17 AM
Time 2 Merc's Avatar
Time 2 Merc
What about a truck that will randomly surge/ and also die. Its very hard to explain and also it happens at the most random times. During the dying part, I can throw it in neutral and gas it and nothing happens and i can also just throw it in any gear and gas it and nothing happens. When i do it with it in gear sometimes i'll hear a knocking noise as i give it gas,i'll then turn of the truck then it runs fine.
Old Nov 5, 2011 | 10:26 AM
Brian_'s Avatar
Brian_
Originally Posted by master tech
Brian
how hard of a fix is that since the tranny will have to come out for that of course?
