Transmissions
Old Nov 18, 2011 | 10:33 PM
  #41
leppy89's Avatar
leppy89
Got a question,
1997 Dakota Sport
17X,XXX
5.2L
4X2
5-speed
I recently discovered the transmission case cracking apart at the transmission mount. I don't know if I'll be able to drive on it much longer. I can only think of either A) replacing the transmission with a new/used one, B) see if someone can weld new material to the case, but its aluminum and I'm not sure how easy it'll be because its cast ( or if it will hold up ), C) replace the case ( if I can even do that without getting it off of another transmission )
Any suggestions?
Old Nov 19, 2011 | 12:17 AM
  #42
master tech's Avatar
master tech
Site Moderator & Tech
If you can and have the tools, replace the case. If not then replace it. Don't try to weld the case. Been there wasn't pretty.
Old Nov 19, 2011 | 12:21 AM
  #43
thunder98110's Avatar
thunder98110
whats a reasonable price for a shop to:
install a stall, and replace the valvebody?
Old Nov 19, 2011 | 12:32 AM
  #44
master tech
You can check with alldata if you have access. But I would say two hours labor plus parts and adjust the bands too. Thats if you have are 44/46RE transmission. Same price for a 45RFE transmission too.
Old Nov 19, 2011 | 12:35 AM
  #45
master tech
girlwithatruck
Try this first, Put the shifter in low gear at a stop and the drive and move the shifter up to shift into 2nd gear and then drive, does it shift into 3rd gear? If it does, the governor is sticking.
Old Nov 19, 2011 | 12:37 AM
  #46
master tech
dakcc4x4
You may have bad seals. You can try seal softer. And see if that helps.
Old Nov 19, 2011 | 12:40 AM
  #47
master tech
crashgordan
Dealers are trying to make a fast buck with flushes. There should do what you have ask them to do. I don't like doing flushes. I want to pull the pan and see what is going on in the pan. I would change the filter every 15k.
Old Nov 19, 2011 | 12:42 AM
  #48
master tech
mxbmxrider2
My first guess would be a bearing or a shift lever valve. I would try to isolate the sound and then post.
Old Nov 19, 2011 | 12:47 AM
  #49
thunder98110
a shop told me it would take 5hrs to drop the trans.
Old Nov 19, 2011 | 01:02 AM
  #50
master tech
I would go to another shop. 5 hours is way to much. I'll post in the morning on what dodge says on a warranty repair.
