Transmissions
Old Oct 22, 2012 | 12:51 PM
  #81
MerlinBoone's Avatar
MerlinBoone
Default Sticking Gear Shifter
I have a 2004 Dakota with automatic transmission and recently that gear shifter has begun to stick in park. I've tried having brake light switch replaced, the usual brake press, and a number of other things. Sometimes it will go in to gear after a few minutes struggle but most usually it's only after pulling down with both hands and lending some weight to it. I'm not sure what to do to get it fixed.
Old Oct 22, 2012 | 06:15 PM
  #82
DK Pony's Avatar
DK Pony
nevermind
Old Oct 27, 2012 | 01:01 AM
  #83
moparbill's Avatar
moparbill
Default tranny slip
hi this is moparbill.i hope u can help.i hava 2000 ram1500 sport.5.9,4 speed auto.4 weel drive.i changed the trans controll solenoid last year.recently the trans would go about half mile then no forward or reverse.let it sit couple hrs and it would repete that.so i pulled the pan and changed the solenoid again.now its slipping pretty bad.what does the govenor pressure solenoid and govenor sensor controll?also how do i torqe the bands?i was told 125 lbs per inch.do i back it off 2 turns?please help. thanks
Old Nov 2, 2012 | 10:30 AM
  #84
trakdafam781's Avatar
trakdafam781
I have a 2002 Dakota 4.7 automatic tranny sometimes it slips out of gear example reverse to park or n. what the problem and is it hard to change the fluid I'm usually very busy and never had time to change fluid it.
Posted from Dodgeforum.com App for Android
Old Nov 2, 2012 | 11:15 AM
  #85
johnnyjack1's Avatar
johnnyjack1
Good morning, I have a couple questions. I am going to remove my sons transmission today to install a new clutch and related parts. It is a 97 dakota shorty 2wd 4 banger.
I removed two aft fasteners from the little floor console but cannot find the forward one so I can remove the stick. Also I can't find my torque specs for the 18 mm bolts on the bell housing. I think the flywheel bolts are 95 foot pounds and the pressure plate are 25 foot pounds. Both use red locktite.
I did search but this is so big now that it is hard to find anything.
Thank you very much.
Old Nov 2, 2012 | 11:34 AM
  #86
dodgeramguy85's Avatar
dodgeramguy85
There should be 4 bolts that hold the shift tower in. Once unbolted should just pull right out. Im not sure of the torque specs. Only thing I know is bellhousing bolts torque at 28 ft.lb
Old Nov 2, 2012 | 07:53 PM
  #87
johnnyjack1
Thanks Dodgeguy, the small console is differant than that. The bellhousing bolts
on there are way tighter than that. Just my luck. On reinstall, I will torque them to
only to 28 ft.lb.
Old Dec 1, 2012 | 12:59 AM
  #88
LugoMS's Avatar
LugoMS
Hello everyone. This is my first post here and I am glad I found this thread. I have a 1999 V6 Dakota with an automatic transmission and roughly 187,000 miles. I recently have been having issues with my transmission. The most frequent is issue is that it feels like the overdrive doesn't engage but on that same note I'm not to sure what my RPM's should be at when cruising at 70mph. The other issue that comes and goes is sometimes the truck does not down shift all the way and it requires me to take off in a higher gear. I drained the fluid and put in a new filter. While I have the pan off, is there anything (sensor or otherwise) I should replace before buttoning transmission pan? Thanks for all the help in advance.
Mike
Old Dec 13, 2012 | 04:28 AM
  #89
keith owens's Avatar
keith owens
Default 1997 dodge dakota 5 speed 318 engine transmission noise
truck has 325k miles never had no issues always serviced with synthetic fluid from the start bought new and changed it over problem is the transmission has a slight chattering sound when in gear while driving and over 50 mph it makes a weird noise sounds like a bearing chirping transmission is not hard to change gears or anything slides right into gears nice and tight has a newer clutch as well any ideas would be appreciated use the truck daily to haul a trailer and don't need it broke down on the side of the road
Old Jan 7, 2013 | 08:43 PM
  #90
hongkong076's Avatar
hongkong076
I recently have a load squeal coming from mine I have a "98 2wd with a 3.9magnum, I don't know the trans. Anything?
