Lower back pain from stock '99 Dakota Sport seats
Old 10-02-2012, 06:50 PM
betelgeuse4721's Avatar
betelgeuse4721
betelgeuse4721 is offline
Default Lower back pain from stock '99 Dakota Sport seats
Has anyone else experienced this?
It seems when I scoot all the way to the back of the seat, I end up having a lot of pressure on my lower back which is leading to some sciatica symptoms (tingling pain in lower back and legs).
Are there special cushions designed for Dakota seats?
I'm 24 btw, so it's not just old age haha.
Thanks,
Brady
Old 10-02-2012, 07:19 PM
moe7404's Avatar
moe7404
moe7404 is offline
go to to a salvage yard and see if a different model dakota has a better seat. or a ram truck. all so a seat out of some dodge car might fit. good luck.
Old 10-02-2012, 08:49 PM
Tom A's Avatar
Tom A
Tom A is offline
Section Moderator
Dodge Forum Moderator
My stock seats sucked, so I replaced them with some Corbeaus. Problem solved (though not very inexpensively).
And I am just old.
Old 10-03-2012, 12:34 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
I have a terribly painful lower back what I use is a Memory Foam Pillow. Just dye the cover black or brown or it will get ugly fast
http://www.target.com/p/memory-foam-..._gpa=pla&ci_kw=
Old 10-03-2012, 09:43 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Exclamation
At your age having this problem means you need to see a chiropractor something is wrong at that age you can usually sit on a rock for hours and not have any problems.
Youth how wonderfully strong and pliable you are at that age don’t abuse it get it checked out ignoring it can cause you more pain if untreated.
Your back needs looked at
A question do you put your wallet in your back pocket and sit on it as you drive?
If you do STOP THAT NOW that is part of your problem or the problem.
Old 10-03-2012, 05:53 PM
bluedodge23's Avatar
bluedodge23
bluedodge23 is offline
I thought it was just me. Mine kills my lower back too.
Old 10-03-2012, 07:17 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Talking
If I remember correctly they are kind of narrow so if you are a little big in the behind part of you is just hanging off the side of the seat and the other side of you is crammed next to the center arm rest kind of pinched in.
I have bench seats with lots of behind room I like my bench seats not fancy but comfortable for me. I did have a custom shop modify my bench seats somewhat with custom fabric not vinyl and had them ad more foam in certain places. First thing I did on my Dakota I guess it worked.
Old 10-03-2012, 09:05 PM
betelgeuse4721
Hey guys thanks for the feedback, I really appreciate it.
I used to drive all the time with a bulky wallet in my back pocket but I've stopped doing that for about a month now - it does make a difference.
Besides installing an aftermarket seat, the best thing I've found after a good amount of research is this product:
Amazon Amazon
Has anyone tried this? I'll feel like an old lad with this thing LOL!!
This one is more expensive but seems like it would solve the problem as well:
Amazon Amazon
Thanks in advance,
Brady
Quick Reply: Lower back pain from stock '99 Dakota Sport seats
