1998 Dodge Dakota Sport 4WD 5.2 L V-8 Magnum manual transmission. Battery has 13.2 volts. No power, no lights, no dash warning lights except for the brake light oddly enough. There’s a constant clicking sound from the dash near the glove box when the door is opened. The voltage at the battery does not change when I try to start it. The fuse box under the hood has 13.2 volts to it. The fuses all look good. I pulled relays on at a time and tried to start it with no luck.
Clean the battery terminals....... Next, I would make sure you are getting power to the ignition switch, and if that's ok, make sure you are getting power OUT of the switch in the right places.
Yeah I’ve got nothing. All the warning lights on the dash don’t light up weirdly enough the brake light on the dash lights up. The battery is 13 V the power box under the hood has 13 V
