Any interest here in better mpg mods?
Old Dec 15, 2021 | 07:32 PM
  #201
steve05ram360's Avatar
steve05ram360
new intake tube arrived, same one as in the kit... so back it goes, sad. there is no way that tube fits the throttle body...
Old Dec 19, 2021 | 08:05 PM
  #202
steve05ram360
hp tuners writeup...
https://moparconnectionmagazine.com/...ptuners-mpvi2/
Old Dec 20, 2021 | 10:35 PM
  #203
steve05ram360
HP tuner interface update done, need to pull the Dak file next
70mm throttle body delivered...
Old Dec 21, 2021 | 08:20 AM
  #204
steve05ram360
So I now have some choices to make... install 70mm w/o any other changes (which is what the test engineer in me would do as it would be testing just that change alone), start tuning with HPT (which again is what the test engineer in me would do as it has the biggest ROI) or... just get going on both, do the install and start tuning.
Still on the plate for the engine are:
  • 70mm TB install
  • HP Tuner install
  • Fan clutch removal
  • 180* stat with tweeks to get it to run at 190-195ish degrees
  • Modified air box
  • Intake tube
Minimal aero mods still to be done (may do these next week and be done with them)
  • Front air dam
  • Vertical bed seals
Any thoughts from anyone interested?
Old Dec 21, 2021 | 09:53 AM
  #205
One change at a time. I agree with your inner engineer. Do the throttle body first, and see how that affects power/economy. That would be a useful bit of info for EVERYONE with a 4.7.
Old Dec 21, 2021 | 10:20 AM
  #206
steve05ram360
Yeah this guy claimed a pretty big jump...
BBK 70m Throttle Body MPG gain - +1.7mpg ....
https://www.jeepforum.com/threads/4-...#post-34960297
Old Dec 21, 2021 | 11:02 AM
  #207
V8Cowboy's Avatar
V8Cowboy
I think you might as well do both mods together, as stated the 70Mmm should be given a decent increase and start tuning on this "proven" TB to get the most out of it.
Don't think it will be a dissapointment to install the TB, so even when done only this mod, will probably result it;s staying on there and continue with the HPTune afterwards.
Good luck, seems i have too hunt for one over here too.
Old Dec 21, 2021 | 11:06 AM
  #208
V8Cowboy's Avatar
V8Cowboy
As i understand i should be looking for an aftermarket TB of 70mm because this one will gain the most ?
There are some improvements over the years on the oem ones, like mine the 2000 has the smal TB on it, so i'll have too look for a later year TB of a 4.7L or get a aftermarket 70mm TB.
Old Dec 21, 2021 | 12:40 PM
  #209
steve05ram360
I will do the TB 1st.. just found out I need a network connection for JTEC program downloading, which makes no sense but this is from HPT. What that means is I probably need to get a better laptop and activate the hot spot feature on the phone to do tuning while out on the road (which is what I always do).
Old Dec 22, 2021 | 08:31 AM
  #210
steve05ram360
Throttle body... goes on sometime this week, hoping to get the little womans oldest to do it so he gets more experience & confidence wrenching...
