Introduce Yourself Here!
Old Mar 11, 2013 | 01:37 AM
  #671
boomerhd's Avatar
boomerhd
Hello my name is mark. I drive a 2002 dodge neon es. Lowered on skunk2s.
I just registered and i need some quick answers if possible. Heres my thread.
https://dodgeforum.com/forum/2nd-gen...odge-neon.html
Old Mar 12, 2013 | 01:55 AM
  #672
Xerxez's Avatar
Xerxez
Hey my names jay and I just bought an 04 sxt wad wondering if I could get some tips to help up performance and what not
Old Mar 15, 2013 | 08:12 AM
  #673
Pam Rice Church's Avatar
Pam Rice Church
Exclamation New to site need help with my dodge neon 2005
Hi, My name is Pam and I have a Dodge Neon Se 2.0 and three weeks ago I had the timing belt replaced since then I had cyl. misfire and crank shaft sensor code errors after a Dodge Dealership changed the timing belt, took it back and they kept saying its not the timing but the Crank shaft sensor so we had them to change it. So after they changed it I still had issues with not "coding" with high rpms took it back and they said the computer shows everything is ok but I may have a secondary issue ( after the 4th diagnostic test) after I left and got home and shut the car off it thumped and then we could hardly start it the following morning took it back and they replaced the timing belt called around noon and said my vibration was not high idle but two motor mounts needs replaced we had another mechanic check them they said we had another 2yrs or so on them ( last june)and after i said i will change them later and 4 hours later the dealership said I have a possible crank shaft sensor and cam shaft sensor error bad ringtones? the car is still sluggish and high idle the car only had one error last year after the crank sensor was changed and it was running great until after the timming belt was replaced tried telling the dealer ship that but they refused to listen to me or my husband they used the previous error as why my car was not working properly and kept saying we need another diagnostic test to find it. any suggestions its the only car I have and can afford right now. I know my car being a mechanics daughter I was raised around cars and know pretty much the basics and know a little about the computer functions. Tired of taking the car there and something else ends up wrong after they work on it.
Old Mar 15, 2013 | 04:18 PM
  #674
darthroush's Avatar
darthroush
Section Moderator
Have you worked your way up the chain at the dealership? There is IMO something wrong with the car from them working on it. Any idea though if they checked to make sure the camshaft position sensor magnet wasn't cracked?
Old Mar 17, 2013 | 07:46 AM
  #675
Pam Rice Church
I have tried to talk to the manager but get he is out of office or he is on the phone and never calls me back. To be honest, no I dont think they checked it but I do think they messed it up and they know they did but dont want to admit it cause they always want to charge me for a diagnostic and I asked if the cam shaft senor would throw a code , I was told no and there is no way for us to check it even with a diagnostic, but yet they still want to do one and charge me for it.
Old Mar 18, 2013 | 12:29 AM
  #676
darthroush's Avatar
darthroush
Section Moderator
Time to go above the manager and not be paying anything else. Saved your receipts, yeah? Take 'em in to whomever it may be next. As for what they told you about the Camshaft Sensor not being able to throw a code, they are full of it. There are a few codes specifically for it (P0340 is the most common), as well as a way to check proper function with a digital multimeter.
Old Mar 18, 2013 | 11:07 AM
  #677
Pam Rice Church
I would go to the owner if I knew it would do any good, I did save all my reciepts from there because he tried to screw me over by saying they didnt find me in their system over a gas hose tubing, I pretty much told that guy he was full of it, thanks for the code, the codeI had was p3009 after the timing belt was replaced, when he told us that the crank sensor needed changed we informed him that we replaced all the sensors last june due to a p2300 code so he used that as the secondary issue not the timing belt, I really dont think they changed this timing belt same issues just no codes. I have an appointment this week with another dodge dealer in the area and I hope they dont try to screw me over .
Old Mar 18, 2013 | 11:13 AM
  #678
lokito50's Avatar
lokito50
Hello my name is Alejandro. I drive a 2003 dodge sx 2.0. Nothing done to it. I'm looking forward to getting some advice/help/tips from these forums.
Thank you.
Old Mar 18, 2013 | 02:47 PM
  #679
valgern1958's Avatar
valgern1958
Default dodge ram 1500 SLT
does anyone know if you must change the lower arm control or can you just change the bushings. 2002 dodge ram 1500 SLT
Old Apr 24, 2013 | 10:15 AM
  #680
sunshineandrainbows12323's Avatar
hello my name is heather. I live in tyrone Pennsylvania. I am the proud owner or an SRT4 dodge neon with stage 1 injectors, larger fuel rail, and an aftermarket air intake.
