Old 06-10-2014, 07:09 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
Good on you to get that!! Only way to be sure.
Here is for reference. I used the flange rib.
Originally Posted by Ham Bone
Got this In today. Time to go measure my pinnion angle.
  #14092
Old 06-10-2014, 08:30 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Sweet thanks. I've been thinking about the best way to get the center line.
Just for kicks. What about the trans side?
Yes I know I can't judge three degrees with my eyeballs haha.
  #14093
Old 06-10-2014, 08:32 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
do what? lol
  #14094
Old 06-10-2014, 09:19 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Well you have to measure it at the trans side of the drive shaft also correct? Because your pinion angle is the relationship between the trans out put shaft and the pinion gear on the axle.
  #14095
Old 06-11-2014, 01:53 PM
Jimythefan's Avatar
Jimythefan
Jimythefan is offline
Changed out both door seal gaskets with new Mopar gaskets. My pass side was leaking a little soaking the carpet.
  #14096
Old 06-12-2014, 03:13 PM
djbucky3's Avatar
djbucky3
djbucky3 is offline
Might be having an issue like that.. Where'd ya get em at?
  #14097
Old 06-12-2014, 06:15 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,266 Likes on 3,013 Posts
LMC truck has them, as well as a few other places.
Do you hear wind noise thru your doors at highway speeds? If so, try bending the window frames in just a bit before you spring for new seals.
  #14098
Old 06-12-2014, 09:23 PM
Arde's Avatar
Arde
Arde is offline
Speaking of window frames, I sure do miss wing windows, oh well.
  #14099
Old 06-12-2014, 10:10 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Wildman4x4nut is offline
HB, Yes your pinion angle is set by the transmission angle. You want the two of them to match. When and if you ever go to a CV joint driveline then you set the pinion angle to match the driveline angle -1 degree.
  #14100
Old 06-13-2014, 09:27 AM
djbucky3's Avatar
djbucky3
djbucky3 is offline
not sure, normally have the music up.. will check on the way to work! but the water coming in is becoming a bit of an issue
Quick Reply: What Did You Do To Your 2ND GEN RAM Today?
