Old Jul 25, 2020 | 09:50 AM
  #16531
Jimythefan's Avatar
Jimythefan
My thermostat froze in the open position so I thought I'd tackle that this morning. Had all my ducks in a row, new stant 180 thermostat, felpro gasket, and all the tools layed out. Everything went fine till the first housing bolt. Yep, snapped right off. Put it all back together and filled it with coolant. I'll deal with this when the weather cools down. Lucky me.
Old Jul 25, 2020 | 12:30 PM
  #16532
Spillage's Avatar
Spillage
My morning (after getting a haircut, ‘cause I was doing a great Robinson Crusoe), I finished stripping the foam off the headliner.
And I found some bolts for a fellow member.
The rest of the day is a few small honey-do fixes around the house.
Old Jul 26, 2020 | 04:30 PM
  #16533
racerxv6's Avatar
racerxv6
Oregon Performance Transmission Kit Upgrade kit...
Dropped tranny pan and replaced the following: This solenoid and sensor kit includes the following items:
  • Rostra dual pack shift solenoid – 3-4 and lockup
  • HD 50185 Borg Warner governor pressure solenoid
  • Rostra governor pressure sensor - transducer temperature sensor
  • Output speed sensor
  • Sonnax updated 3-4 accumulator spring
  • Governor pressure solenoid body gasket
Old Jul 29, 2020 | 06:18 PM
  #16534
horace's Avatar
horace
I am having the steering leak repaired on my '97 w/ 210,000, the '97 w/ 266 000 has had brake line problems repaired caused by age & rusting. So I'm stuck driving my '18 HEMI Laramie crew cab
Old Aug 1, 2020 | 01:09 PM
  #16535
Spillage's Avatar
Spillage
Due to the approaching storm, I moved my truck from the (tree covered) driveway to across the front of the house.
I noticed a nice oil spot on the concrete... leaking pinion seal.
I guess I’ll be rebuilding my axle sooner than later.
Old Aug 4, 2020 | 06:37 PM
  #16536
Thomas bridges's Avatar
Thomas bridges
Default pulled a huge 5th wheel no squat
pulled this today
no squat
no squatting
Old Aug 4, 2020 | 06:38 PM
  #16537
Thomas bridges
pulled this today
no squat
no squatting
Old Aug 15, 2020 | 04:24 PM
  #16538
Spillage's Avatar
Spillage
Today I did a bit towards redoing the lid on the center console.
I cut and shaped the foam to fit the backing/frame.
I used CosPlay foam (EVA foam)... it’s dense with a little give... supposed to hold up to 200F conditions.
It cuts easy enough with an Exacto knife, and is supposed to be sandable.
I used a black contact adhesive to layer up the edges... overall it’s about 1/4” thicker than the original.
Next I need to round the corners and top edge... I guess we’ll see how sandable it is.
Old Aug 16, 2020 | 05:24 PM
  #16539
1997DodgeRam's Avatar
1997DodgeRam
Front brake pads.
Since I’ve been off here for a bit I’ll also mention I also paid to have my transfer case resealed, in an effort to stop leaving puddles, and I also had my long ago failed LSD replaced with a Detroit Trutrac. I pulled a bunch of metal pieces from the rear diff 6 or 7 years back but it drove fine so I left it. Fully open it’s a bit sporty to try and pull into traffic in the rain so I finally bit the bullet while it was in there for the transfer case.
I knew that transfer case was a leaky mess but also know I’ve got multiple sources and types of minor of leaks. Next up is replacing the valve cover gaskets and I’ll work on cleaning things up from top to bottom but I’m not making the mess I was so it’s not much of a priority.
Old Aug 16, 2020 | 07:47 PM
  #16540
Originally Posted by 1997DodgeRam
Front brake pads.
Consider doing valve seals while you have the valve covers off. Not real expensive, not real difficult, but, extremely tedious.
