We’ve had plenty of rain, and it’s been sitting under trees in the driveway, so if it was going to get musty, it would have by now.
Also... was driving behind a tar-pot the other day, and it dawned on me... I don’t smell tar.
Then yesterday I was behind a tow truck dragging a car that must have still had the brakes (partially) on, as smoke was bellowing from one wheel... yet again, no smell.
It used to be that you’d smell anything and everything going on outside on other cars... hot clutch, oil on the exhaust, etc. (a fart from a passing motorcyclist)... but that’s not the case now.
I guess the carbon filter is doing its job... much to my surprise.
As a follow up on the cabin air filter.
Replaced the starter motor on the 8.0.... It's been on there awhile, so, both terminals broke off, as opposed to the nuts coming off..... A job that likely only pays half an hour, took me 5..... but, it's done, and it's a truck again. (the old starter was struggling to roll the motor over.....)
It's a little tiny feller. I have seen window fan motors that are bigger.....
I could one-hand it into place. Not what I am used to.
I don't know......
Didn't have to change one before yesterday.
I suspect it is pretty much the exact same thing as the V-8 fellers. A high-torque mini-starter. Gear reduction at that.
, learn something new everyday
I need to figure out where my vacuum leak is, pull the engine replace the rings and valve seals. Also figure out where the gas and weird smell is coming from.
