#5541
Good point.... But after having someone slowly turn the wheel back and forth while I was under the truck I discovered I may not even need to replace mine...I can movement from side to side where the pitman are bolts up and the brace I just bought will eliminate that. That combined with the slight amount Of slop in my steering shaft that I'm replacing should do the trick.
#5543
#5544
Spent some quality time with my truck this weekend........
Started with the driver side bearing hub, upper & lower ball joint & axle u-joint. Was a alot of struggle getting everything apart. The upper ball joint literally exploded using a ball joint press.
Decided to move on to the front drives haft and did the Double Cardan rebuild. Breaking the H Flange was a hiccup there and while tougher than anticipated, wasn't bad in the end.
Next is off to passenger side to fix oil seal, replace upper & lower ball joints and u-joint. I am crossing fingers that the hub is ok or I dont destroy it taking it out.
I guess after this will be time to tackle the plenum. I keep getting the catalytic code and strongly suspect this is an issue.
after that or maybe before hand I need to do something about the charcol canister. Not sure if to buy new or how to go about that yet, haha.
Attachment 12819
Attachment 12820
Pics are of the leftover over shrapnel & the Cardan Joint
Thanks to this forum the job is done, probably would still be wrestling with it without it, haha
Attachment 12819
Attachment 12820
#5547
#5548
Cap, Rotor, Wires, Plugs, PCV Valve (from the dealer only.), air filter, oil change. If your truck is over 100K miles, Pre-cat O2 sensor as well. (NTK, or Denso please.)
#5550
