Old Jun 25, 2011 | 10:31 PM
  #5661
dsertdog56's Avatar
dsertdog56
Put convolute tubing on my power amp wiring. Re ran it and the CB antenna cable through the floor pan.
Put the vinyl flooring back in the truck and re cleaned it.
Stripped and painted my sub enclousure.
Reinstalled the back seat.
Old Jun 26, 2011 | 12:24 PM
  #5662
knoxy's Avatar
knoxy
Installed new shocks on front end. First time shock job for me. rain finally cleared up so I can get back to welding up the door panels.
Old Jun 27, 2011 | 12:24 PM
  #5663
Ralpho's Avatar
Ralpho
My tranny is leaking and may be going bad. Today I found out I need an a/c compressoir so between the both they want 3500.00 I guess at this point its time for it to go.
Old Jun 27, 2011 | 01:35 PM
  #5664
Where is it leaking from? You could probably score a used compressor from the scrap yard pretty cheap.
Old Jun 27, 2011 | 03:24 PM
  #5665
dsertdog56's Avatar
dsertdog56
Yesterday:
Replaced the pump in my carpet shampooer.
Cleaned the seats and center console...many times!
Got the seat mounts, passenger seat and center console back in, along with the electronics and rear seat.
I'm still washing the drivers seat, but it should go in tonight.
Old Jun 27, 2011 | 08:14 PM
  #5666
Ralpho's Avatar
Ralpho
They said the tranny is a 3.00 gasket but you have to take the tranny out and its a 4x4. The compressor is leaking in the shaft. I' found some from online for 250. to 300.00 but they won't charge it or garrenty it. They said between the a/c and tranny its almost as much as I paid for the truck.
Old Jun 27, 2011 | 11:14 PM
  #5667
dsertdog56's Avatar
dsertdog56
Finished my interior tonight...well it's about 92%. The first pic is from Sunday and then here's a finished one
Old Jun 27, 2011 | 11:36 PM
  #5668
Get a compressor from the scrap yard for 50 bucks.
Can you drop the trans yourself? Did they tell you where it was leaking from??
Old Jun 30, 2011 | 09:54 PM
  #5669
dsertdog56's Avatar
dsertdog56
Heated up and rebent my transfer case shifter so the I don't have to lean over and take my eyes off the road or trail to shift. I have to mount it backwards now...but 4 low doesn't end up with your hand about under the dash either!
Old Jul 2, 2011 | 09:46 PM
  #5670
redheadhunter21's Avatar
redheadhunter21
Finished up my tuneup
Wires/cap/rotor/plugs
Plenum fix
timing chain
tb mod
water pump
pcv valve
and then took the truck for a damn good break in run, noticed some improvment the tb and seems to idle a little different
