The Official 2nd Gen RAM Forum OT thread
Old Feb 5, 2013 | 06:31 PM
  #6781
stewie01's Avatar
stewie01
Best and most embarrassing mom ever.
Old Feb 5, 2013 | 06:33 PM
  #6782
crazzywolfie's Avatar
crazzywolfie
i think someone might want grand children
Old Feb 5, 2013 | 06:34 PM
  #6783
Yinzer's Avatar
Yinzer
We'll see 9 months later... haha.
  #6784
aofarrell2's Avatar
aofarrell2
Originally Posted by Jigabop
sure its not a stuck injector? air in the line?
getting good fuel pressure to the injection pump?
injector could also be suffering from too low of a pop pressure and might need a rebuild..
I don't know how to tell a stuck injector.
Good fuel pressure? I think so. Priming doesn't help at all.
i know when I rev it up it smokes bad. Above 900RPM it runs smooth but gulps fuel and I'm not kidding on that.
I found out that pulling the fuel shut off **** out half way and cranking for about 6 seconds then pushing it in and trying twice to start it again and it often but not all times will start. The shut off mechanism is adjusted properly. Also it kept backfiring at me when I gave it ether.
  #6785
stewie01's Avatar
stewie01
You're probably right. Using thumbtacks to hold a condom to the door isn't exactly um.... safe....
  #6786
aofarrell2's Avatar
aofarrell2
And it just gets worse and worse. It's got good fresh fuel too.
Old Feb 5, 2013 | 07:01 PM
  #6787
Jigabop's Avatar
Jigabop
yeah, tack through the condom...thanks for the idea mom, but I think I'll go get a new one WITHOUT a hole in it!
Old Feb 5, 2013 | 07:08 PM
  #6788
Jigabop's Avatar
Jigabop
That's not a surprise
its not a gasoline. it runs on compression alone. if it has glow plugs, those are probably lighting off the ether early...
as for injectors you would need to pull them and take them to an injector shop and have them pop test them.
that will tell you if its a bad injector.
Old Feb 5, 2013 | 08:59 PM
  #6789
aofarrell2's Avatar
aofarrell2
I know it's not a gasoline. I'm not completely ignorant when it comes to diesels. It doesn't have glowplugs either which is the bad part. Sometime later this year I'm gonna equip it with 'em.
Well pulling the injectors is gonna have to wait for now.
Made a little progress on the RAM today. Got the mount installed now just to get that crossmember in...
Old Feb 5, 2013 | 09:04 PM
  #6790
Oh Come on. Where is your sense of ADVENTURE!
