The Official 2nd Gen RAM Forum OT thread
Old Apr 5, 2013 | 12:06 PM
  #8171
Jigabop's Avatar
Jigabop
I definitely call bs on 30mpg v8 in a truck....
ain't happenin.
not in a full size with truck gearing anyway...
now if it were a light pickup with 3.43 gears and a T56 transmission, I might believe 24mpg....but still not 30mpg...
I say that because my Z28 with the 350 LT1, T56 trans (double overdrive 6-spd) and 3.43 posi rear got 20-24mpg if you were easy on the throttle. 70mph was just 1500rpm in that car...
Old Apr 5, 2013 | 12:50 PM
  #8172
ain't happenin.
No highway mode operating in the PCM on those..... not even sure if the code is in the programming for it. I went from 21, to 28 on the Eway just but flipping a couple switches in the programming...... no other changes. Granted, 30 MPG out of a big cube V-8 in a heavy truck is a bit difficult to swallow..... I would LOVE to see the documentation for that.
Old Apr 5, 2013 | 03:27 PM
  #8173
aofarrell2's Avatar
aofarrell2
Originally Posted by stewie01
^^ Why'd you remove the "affectionately known as tech-jockey" from your signature?
What, did you like it? What I replaced it with isn't something you guys will really catch on unless you know me well enough LOL...
The only trouble with leaning out the magnum engines I could see would be the lack of a knock sensor. GM, and I do believe Ford as well, used them on their engines, so when the PCM could actually DETECT pre-ignition, it could dial back timing, and/or increase mixture. Dodge didn't seem to think a knock sensor was necessary on the truck engines.... so, we don't have one. It would take some serious experimentation to get it right, and I suspect it would be a perpetual battle trying to find the right combination. Changing over to a GM OBDII system, WITH a knock sensor, would be MUCH easier.
I had even considered when the time came for my engine to be replaced, getting an LS? Engine and wiring from some GM product or other, and dropping that in place of the 360. Even my old OBDI small block chevy was a torque monster with the TPI..... and a fair few folks have adapted the OBDII sequential systems to the TPI...... That would make an interesting combination.
I've actually considered dropping in a Ford EEC-4 into the Dodge and getting my chip burner. It has a knock sensor and is easy to tune. About the only major thing that'd need to be changed is the fuel system would need a regulator to step it down from 45 to 35PSI. As far as gauges go IDK yet, both Ford and Dodge use Denso gauges, but compatibility might be a question. Oh, and injector firing order will be different but IIRC that can be fixed easily by swapping injector wires around to make the firing order correct. I know I could also fix that in the chip.
Why can't we just learn to love our old school Magnums?
Who said we don't love our Magnums? If we didn't love them we wouldn't be looking for ways to improve them. I think the Magnum has alot of potential that hasn't been realized yet. Maybe, when I get tired of the Dodge using a carb I'll drop in a Ford EFI and see how much improvement I can make...
Old Apr 5, 2013 | 03:34 PM
  #8174
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Putting any other engine in a Dodge is grounds for lynching....
I bought this:
http://www.lowes.com/pd_221014-47120...7C1&facetInfo=
For a catch can, but the fittings are NOT 3/8 in on the catch can, they're more like 1/2-3/4 in. Any help here?
  #8175
aofarrell2's Avatar
aofarrell2
ain't happenin.
Guy that did it had 3.55 in the rear.
No, the "highway mode" is accomplished through the chip, which overrides the EEC programming. The user has to select it through the DPT switch, then the chip adjust to operating conditions as programmed.
Old Apr 5, 2013 | 03:35 PM
  #8176
aofarrell2's Avatar
aofarrell2
I bought this:
Air fittings are either SAE or NPT. They don't mix. Might be your problem.
Old Apr 5, 2013 | 03:37 PM
  #8177
dodge dude94
I bought fittings that said they were for 3/8 in, the filter is 3/8 in. WTF isn't it working?!
Old Apr 5, 2013 | 03:42 PM
  #8178
ain't happenin.
Did I know that?
Old Apr 5, 2013 | 03:51 PM
  #8179
stewie01's Avatar
stewie01
I think I gave you that nickname.
Old Apr 5, 2013 | 04:00 PM
  #8180
Jigabop's Avatar
Jigabop
Originally Posted by jkeaton
Did I know that?
haha
it was a 94.
I miss that car. It got me into too much trouble though so I had to sell it. (got pulled over doing 110 in a 60 and 10 minutes before getting caught, i had the speedo burried on the peg past 150mph and climbed another 1000rpm and still had plenty to go before redline, but the car was getting lift and it freaked me the F out lol. scary when your car feels like its floating rather than being firmly planted on the ground...) sold it to a now ex gf, and she wrecked it more than once...
not to mention she didn't change the fuel pump out like I told her to and it stopped running shortly after. lol
pics before I sold it...
