Ram Body work
Old Jul 14, 2012 | 04:04 PM
  #561
gdstock's Avatar
gdstock
Originally Posted by Girly TT
That is why you keep burning through the paint. finish sanding, is a wetsand by hand, NEVER with a power sander. If the finish is that bad (orange peem, runs, etc), wetsand witg 600 grit, then go over it with 1000 grit, then buff. Never ever ever with an orbital or any power sander. That is for prep work only.
That makes sense. 3M advertises the 1200 g purple discs as the perfect solution for sanding clear. But with my level of no experience, I should probably have been my usuual suspecting self. But the sanding is so labvor intensive, and being a Type A personality, I want everything done quickly.....severe lacck of patience on my part.
Originally Posted by kejobe
You can finish sand with an orbital as long as you have a foam pad. Its about ½" thick and attatches to the pad of the sander. It helps prevent any "hard" spots when sanding. It does not do much of anything for a smooth finish though. It will give an OEM look (slight orange peel). In other words, these are used more in collision shops (seen and used them) than custom (never seen or used) and Ive worked in both.
No foam pad on mine. But this makes perfect sense.
BTW, GD, lookin real good!
Thanks, guys.
Although it is not perfect, and I am seldom, if ever, satisgfied with less than perfect, I did not set an unrealistic espectation of perfection on this project. I picked up this truck to help out a brother-in-law, and decided to keep it as a learning project. In that regard, it has been a successful venture. And it I have to sand and redo areas a number of time to get it right, it is not a problem. The only way to learn is do it until it is right. The down side is the cost has already run more than the value of the truck, but when one considers the investment in learning, then it will be a worthwhile investment. I have never been one for looking for the cheapest way out. But I have always taken pride in the things I have built.
Old Jul 18, 2012 | 10:34 PM
  #562
gdstock's Avatar
gdstock
After a little delay due to work travel and the radiator issue, spent a little time on body work...or prepping for more.
Removed rear bumper.
It has a couple small dents on each side.
Will try to hammer (or hydraulic press) dents out and then sand down, try to prime with etching primer and paint. Only time and effort will tell!
Old Jul 22, 2012 | 08:30 PM
  #563
gdstock's Avatar
gdstock
Marked the back side of bumper so I would know where the hamer out dents.
Sanded chrome with 80 grit then 120 grit. This coat of filler on some hammer marks that did not sand out.
Primer and then some glzing puty on small imperfections.
Bumper painted blakc:
And of course it was masked off for blue stripe!
Old Jul 22, 2012 | 08:33 PM
  #564
Wombat Ranger's Avatar
Wombat Ranger
Why mask it off when spraying black instead of just spraying blue over the black?
Old Jul 22, 2012 | 08:54 PM
  #565
gdstock's Avatar
gdstock
If I spray over, then the edge of the blue is higher and will tend to burn when buffing.....don't ask how I know.....
Old Jul 22, 2012 | 08:56 PM
  #566
Spray the blue. Let it set nicely, mask it off, spray the black.
Old Jul 22, 2012 | 09:01 PM
  #567
gdstock's Avatar
gdstock
Did black first. The heavy mettalic in the blue is a b**** to clean out of the gun, so I saved the "fun" part till last!
Old Jul 23, 2012 | 11:40 AM
  #568
Girly TT's Avatar
Girly TT
Then you are buffing on too high of a speed, and/or with not enough compound. Lower the speed and use a proper compound and proper pad.
For stripes, you lay the color down on the entire vehicle, mask off your lines on the entire vehicle, cover the remaining parts with a plastic tarp, lay down color. Let it dry, clearcoat the entire vehicle with at least 3 coats. That is how you get a smooth finish.
Wetsand by hand with 600 grit wet/dry paper and a foam sanding block, buff with an "abrasive" buffing compound, then switch to a finishing compound/glaze. Different people prefer different types of pads. Some foam, some wool, go to your local paint supply store and ask them what they recommend for pads. The pad and compound will make or break the finish.
Then wax.
Black is tough to get it without swirls, but if you take your time, it will come out like glass.
We did all of the paint work on this front end. It came out looking better than the factory paint on the rest of the car
Body work is not a fast process, you will keep having to redo things over and over again if you try to speed through it (burning through paint, sanding through paint, etc).
Old Jul 23, 2012 | 10:31 PM
  #569
gdstock's Avatar
gdstock
Then wax.
My Type A personality makes me want to rush. I am learning and fixing mistakes is increasing the cost, but this is a learning project to begin with.
Thanks for the pointers. I also have a few places where I buffed too much and have to touch up. Biggest problem is I can't buy good quality paint here in town. Gotta go to the city....and can't go just any day, so this slows me down a little.
Worked on repainting the air dam where some of the blue came off and striped the bumper today. Sanded a little more than originally. You may also remember that it did not line up exactly when I put the trim pieces on the bumper, so this corrects that also. Still need to move the top bumper cap over to the pass side a little. Hood is raised a couple of inches making it look more out of line than it is....
Paper used to mask bumper screwed me. Where I sprayed to set up gun, it bled through the paper and made spots on black paint....so now I have to sand and repaint the black. This was paper from Ace Hardware, and appears to be thinner than what I have been using from PPG distributor....won't use that again!
Old Jul 24, 2012 | 10:40 AM
  #570
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Your lines aren't straight.
And I am not talking about the alignment either...one of the tape lines looks crooked.
