Not a ram, but need a little speedometer help
Old 04-08-2012, 07:24 AM
kejobe's Avatar
kejobe
kejobe is offline
Default Not a ram, but need a little speedometer help
Ok, I just bought a '99 Accord with a 2.3L 5 speed to help out the Rams mpg. Has 154xxx on the clock, runs and drives with no problems.
What I need a little help with is the speedo DOES work, but, its off. While pacing my wifes 2012 Civic, at 40 mph my speedo reads 43. Now at 60, it reads about 64. And at 70, it reads 75.
Would the VSS cause this? Or would I need to take it to the dealer to reprogram the ECU? I havent found much online about a fix, but have found a few others with the same problem. I know the VSS can go bad and the speedo not work, or work intermitantly (sp?), but I dont think it would cause it to be off by a varying amount.
Any ideas?
Old 04-08-2012, 07:26 AM
kejobe's Avatar
kejobe
kejobe is offline
Oh, and it does have the stock wheels and stock size tires.
Old 04-08-2012, 08:29 AM
Nereaga's Avatar
Nereaga
Nereaga is offline
I use this forum for the wife's 04 Accord... They are a bit slower with replies, but some of the guys know these cars
http://www.hondaaccordforum.com/forum/
not sure if I can post that link or not... I'm sure I'll get smashed for it here on DF!
Old 04-08-2012, 09:39 AM
kejobe's Avatar
kejobe
kejobe is offline
ok, I'll take a look.
Just checked speedo vs. GPS:
Speedo GPS
30-28
35-33
40-38
45-43
50-48
55-52
60-57
65-61
70-66
75-71
80-75
85-81
90-85
Now a DuraCrap VSS is $75. I don't want to spend the money if I dont need to, but I'm lost on this.
Old 04-08-2012, 11:01 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,273 Likes on 3,020 Posts
If you know it's off, and you know how much it's off, and it is consistent, just keep that in mind while driving, and don't worry about fixing it. The VSS is obviously working, after all, it's just a pulse generator... replacing it more than likely won't make the least bit of difference.
Old 04-08-2012, 11:20 AM
kejobe's Avatar
kejobe
kejobe is offline
Yeah, but the thing is, is its off from 2 mph to 5 mph.
Not to mention it just bugs the hell outa me.
Old 04-08-2012, 11:26 AM
HeyYou is offline
You could try pulling the VSS and cleaning it.......
If it is a tire size, or programming problem, speed should be off by a set percentage. The faster you go, the wronger it gets. If it is a variable error, might be the gauge.
Old 04-08-2012, 11:49 AM
kejobe's Avatar
kejobe
kejobe is offline
Yeah, might have to deal with it. At least it reads faster than Im going though. Theory would have it that it may help against tickets. Hehe, yeah right
Old 04-08-2012, 12:03 PM
HeyYou is offline
Wishful thinking?
Old 04-08-2012, 12:35 PM
SilverSS's Avatar
SilverSS
SilverSS is offline
I'd just let it go. It's pretty close. Motorcycles are usually like that also. The faster you go the farther off the true speed is. Maybe put a size smaller tire on it next time you get tires. That should make it a little closer lol.
Quick Reply: Not a ram, but need a little speedometer help
