E Fan and other work
Old May 23, 2012 | 12:36 AM
  #131
Wh1t3NuKle's Avatar
Wh1t3NuKle
gd -- you're gonna be ecstatic about the fans. Sunday they were a charm given the slow speed and longer idle times from trail running and the occasional romp over snow drifts.
Very easily heard and my buddies were like -- here comes the jet engine!
Old May 23, 2012 | 12:45 AM
  #132
gdstock's Avatar
gdstock
Took wife and FIL out to dinner tonight and stopped by Autozone on the way home. Couple guys working on a beat up 2nd gen. I left engine running with AC on (still 90 degrees) and they both looked over with a quizzical look when I pulled up. With AC on both fans running 100%. Had to turn radio all the way down before I could hear it, and barely...but upon opening the door they were whining. Extra soundproofing in cab really helps. I am almost comfortable enough to put it on the highway for a road trip. I plug in MTG to look at actual number sometimes. I am amazed at how cool this engine runs and how quickly those fans pull the temp down. It may have cooled as well with mech fan, but I had no reason to check actual temp so I can't argue one way or another. I do like the extra roominess in the engine bay. Less clutter looks better.
Old May 23, 2012 | 09:51 PM
  #133
gdstock's Avatar
gdstock
I've driven the Ram to work and around town for three days now. Temp hangs around 183 degrees and it has been 90 and above outside. Did have a short panic moment this morning. Opened gargae door, got in truck and crankied it up. Fans started running 100% before I got it out of garage! Then I realized the AC was turned on with the fan at low speed........syetem is set up to turn fans on at 185 OR if AC is turned on, then they both run 100%. Turned off AC and all was good!
Old May 24, 2012 | 10:50 PM
  #134
QuadCabLuv's Avatar
QuadCabLuv
I just realized that the only thing I havent figured out how to do is make the fan come on with the a/c. How did you do yours?
Old May 24, 2012 | 10:59 PM
  #135
Wombat Ranger's Avatar
Wombat Ranger
If your harness came with the wire you can splice it into the correct output on the A/C relay. That's what I did.
Old May 24, 2012 | 11:06 PM
  #136
gdstock's Avatar
gdstock
Mine came with a wire to tap AC clutch. If yous didn't it could still be done. If you can post the wiring diagram for yours, we can see the best way to tap in.
And Wh1t3NuKle, I am ecstatic about the e-fan. I watch temp now just to see how it stays soncstant, and in traffic when it starts to go up, seeing how fast it comes back down. I have not installe dthe status indicator yet. Can't decide where to put it. May put it on gauge pod on A Pillar.
Old May 24, 2012 | 11:18 PM
  #137
Wombat Ranger
Are you wanting my diagram? Cuz mines different I think...OBD1
Old May 24, 2012 | 11:41 PM
  #138
gdstock's Avatar
gdstock
If you have the diagram, I can figger it. You can PM (if you can add attachment?) of e-mail or post here. OBDI or II doesn't matter, it doesn't go through PCM. I used a realy to add this to my Jag several years ago to keep the temp from shhoting up so fast before fans cut on.
I'll probably install e-fans on my Yota next .... or when I get to it.....
Old May 24, 2012 | 11:57 PM
  #139
Wombat Ranger
I wanna say I hit wire 86... definitely either that or 87. But it's late and I'm not gonna go check on it right now.
What I did to find the right one was run the truck (it needs to be below the temp where it kicks on automatically) and strip enough of that wire to stick it down there and test each relay wire. You gotta make sure it stays off when the A/C is clutch is disengaged, and comes on when the clutch engages. I had a bit of an issue with this cuz my A/C system sucks(low pressure, probably leaks pretty good), so the clutch comes on and off sporadically, but once I figure that out it was easy.
Old May 25, 2012 | 12:08 AM
  #140
gdstock's Avatar
gdstock
I would not hit ABS relay. Is your Trailer relay vacant?
And do you have diagram on fan control. Ideal way is to let temp control fan, and AC override the temp.
