Wheeling a fullsize
Old May 16, 2014 | 05:21 AM
  #451
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Nukle,
What are you going to do for lower gears? Reason I ask is because I'm wondering if you have thought about using a case doubler? Gives you dual transfer cases so you can select what ratio you want or you can double it up and have a deep crawl.
Wildman
Old May 16, 2014 | 10:21 AM
  #452
Wh1t3NuKle's Avatar
Wh1t3NuKle
I've got the 241OR 4:1 tcase sitting here.
But don't let the cat out on that other thing.....!!!
Old May 16, 2014 | 07:14 PM
  #453
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by Wh1t3NuKle
Ok, here is the portion that did the following beauty mark.
It's shown in realtime so you get a sense of the pace. It's quite painful and is also why I slapped in a few songs.
https://www.youtube.com/watch?v=1SuO...4&noredirect=1
Ok, last year's video above of the same waterfall obstacle. Ran on 35's and only 4" lift then.
This year about 5" lift and the 37s...still open front diff. The obstacle was modified by someone. The big ledge held by the roots is gone, however, many more rocks...and a large one placed with some strateeegery. lol I still needed some rock stacking...
I was lazy in finding music. I may change it later.
Old May 17, 2014 | 09:39 PM
  #454
corbo1962's Avatar
corbo1962
Your truck is definitely more capable now with the bigger tires and extra lift. What are waiting for on the axle swap. The gears and lockers will make a huge difference
Old May 18, 2014 | 08:12 PM
  #455
Wh1t3NuKle's Avatar
Wh1t3NuKle
Yup yup...can't wait to be getting those bigger metal things up under there. I'm waiting on getting the gears, install kits (decide to have shop install or myself), then figure what front shock setup....those are the major items preceding. Oh yeah...and wheels.
Old May 18, 2014 | 08:29 PM
  #456
Ham Bone's Avatar
Ham Bone
What axles are you going with again? I recall them not being dodge axles.
And were those fancy double control arm brackets on the 44 or on the new axle going under?
Old May 18, 2014 | 10:44 PM
  #457
corbo1962's Avatar
corbo1962
What size gears did you decide on? Sounds like you still have some things to iron out.
I think I'm going to try a 3" body lift. I guess now before I start fabbing the bumpers would be the best time. The Las Cruces chili challenge is in October this year and I'm thinking I want to run a few of the trails. They have the same grading system as Moab and I'm thinking I could handle the 6 rated and possible the 7's
Old May 19, 2014 | 12:58 AM
  #458
Wh1t3NuKle's Avatar
Wh1t3NuKle
Front is 97 Ford HP60 with factory inner 35 spline and 5.13 gears
Rear is 01 Dodge D70u
The fancy pants brackets I made are on the 44. As of now I'm not going to run 4 link on the Ford axle.
Originally was going with 5.13s. However, decided to go with 4.88 instead. Stronger because pinion size compared to 5.13s and auto tranny will tolerate it fine. I'll have deep enough gearing in the tcase, which is the primary reason. I'm not interested in full on 100+:1 crawl ratio.
You won't have any issue with the BL. I'll look up that challenge. btw, when you coming to run the Rubicon with Wildman and me? How is this September...?
Went with a bud to help him shakedown his built Dakota. He's been working it for a good number of years and this is first time he's really got to flex it and do a little wheeling.
he is very happy with the results as it was pushed maybe 90%. No major binding or clearance issues. Limit straps are just right actually. He SASed it with a wagoneer axle for the front and went 14ff for the rear. Rear is lincoln locked and front is open. Tcase is Dana300 that is flipped, so he has options to engage front only, yet the shifters are a real PITA to move. Couldn't get it into 4wd for like 10 minutes.
The burb got stuck in the mud. I pulled him out and his driver front tire just about peeled off the rim. Fortunately he had a spare. The mud was unforgiving with about a 2" crust, which went full globular underneath.
I climbed the pyramid with ease now. About 1.5" driveshaft clearance on the last lip now.
A different obstacle route that I walked easily.
Old May 19, 2014 | 09:44 AM
  #459
corbo1962's Avatar
corbo1962
Cool Pics, that Dakota looks bad ***!
Old May 19, 2014 | 09:50 AM
  #460
corbo1962's Avatar
corbo1962
WK Said....You won't have any issue with the BL. I'll look up that challenge. btw, when you coming to run the Rubicon with Wildman and me? How is this September...?
I do want to come out and see what the Rub is all about! September is a bad month for me, work is planning another turn around and I have a Deer hunt at the end of that month. Next spring, early summer might be a good time.
