Wheeling a fullsize
Old Aug 19, 2014 | 10:46 PM
  #611
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by Wildman4x4nut
Is that a new kind of air shock hanging down there??? Hehehe, I thought the 1350 joints I was using in my Jeep were big. What kind of heavy equipment does that joint go into?
That is the ultimate air shock...it's mounted to the air!!
Yeah, I didn't get a chance to ask the mean piece of yokes that ujoint holds. I was thinking one of those gigantic quarry dump trucks.
Transfer Case
Done -> Mount BB to 241, RTV
Done -> Assemble shifters for 241 and BB (still needs lever installed though)
Linkage from my truck and from the 241 left to right, respectively.
Old Aug 20, 2014 | 01:02 PM
  #612
Rescue35's Avatar
Rescue35
What made you go with the Black Box over a Strongbox or other 231/241 planetary doubler.
I have been considering a Strong Box as I plan to run a Ford NP205 behind my double so I can sacrifice the 231 for the gearset.
Old Aug 20, 2014 | 04:12 PM
  #613
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Sorry if I missed something, but what front driveshaft are you going with?
Old Aug 21, 2014 | 12:53 AM
  #614
Wh1t3NuKle's Avatar
Wh1t3NuKle
Default Floor shifter and Sway Bar Link Tabs
Floor shifter has a flange that is to be used in any means needed by end user. I decided to use 4 bolts and have a mating plate on other side of body sheet metal to clamp. Large enough to spread the load, however, the shifter is pretty smooth.
I also cut out tabs from some 3/8" plate. Drilled the holes for my existing sway bar links. Got driver side fully welded on in the dark. Passenger is tacked and will finish tomorrow.
Putting my previous dual adjustable arms up for sale. 1 set of rod ends could go with them.
Old Aug 21, 2014 | 01:02 AM
  #615
Wh1t3NuKle's Avatar
Wh1t3NuKle
I've reviewed the BB, the Strong Box, and the Box4rocks doubler over the past year. All are aftermarket planetary gear boxes, not mated tcases. I talked to many people, searched out reviews, etc.
My choice came down to support, reviews, and quality. The BB is considered a production level product with alot of background to stand on. Strong Box has stumbled, but is quickly moving to production level, however, I can't speak to it's quality. The box4rocks was actually my first choice, however, the 1 man show is hit and miss. I just couldn't rely on that.
Mating two tcases is not bad, but just a real tough thing to package. Requires an adapter and sometimes aluminum welding. They don't have a place in street vehicles in my opinion.
I actually had not mentioned it. My plan is to retube my factory front one.
Old Aug 22, 2014 | 01:38 AM
  #616
Wh1t3NuKle's Avatar
Wh1t3NuKle
Got alot done today
Done --> Rear brake line on axle
Done --> Rear brake line feed
Done --> Rear shock mounts
Bleed Brakes
Done --> Front brake lines, T junction
Grease locking hubs
Transfer Case
Done --> Assemble shifters for 241 and BB
Oil in BB and check 241
Front axle
Done -> Check alignment, position, toe-in, and steering wheel
Torque all fasteners
Done -> control arms -- 140 ft lbs
Done -> track bar -- 130 ft lbs
shocks
Done --> Determine Sway Link tab location
Determine shock reservoir mounting location
Steering
Done -> Torque all TREs --70 ft lbs
Done -> Install cotter pins
Done -> Torque pitman arm @ draglink -- 70 ft lbs
Done -> Torque pitman arm on gearbox -- 185 ft lbs
Add Tranny fluid!
Design crossmember
Diff fluid
ARB hookups
Breather tubes
Charge shocks with N2
Should be driveable Friday...
Cleaning up tonight...got friggen spooked!!
About 3 fingers thick. Biggest one this close to the house. Just weird he worked his way up there while I was working, making all kinds of noise. Buddy came over to help with his BB gun. That didn't take him all out b/c his shooting sucks. lol But was enough to reduce motion to shovel him.
Old Aug 22, 2014 | 07:46 AM
  #617
Ham Bone's Avatar
Ham Bone
Yea cool big *** snake good job.
Look at that cotter pin, aren't you fancy lol.
I can't wait to see this thing in action
Old Aug 23, 2014 | 07:48 PM
  #618
Wh1t3NuKle's Avatar
Wh1t3NuKle
See the tack weld near the cotter pin?
I'm down to the last darn 1%
Brakes bled. That was a chore doing it solo.
Here is the shock charging session
Steering appears spot on....
Charged to 250 psi to start. It added 2" of lift.
Last 1%
Rear shocks mount on axle. Kinda tough with them extended.
Diff fluid. Pulled brain fart about 11pm last night. So laugh it up. Looked at the plug and was like...I don't have a square tool to go in there.... lol So no fluid last night.
Tcase shfiters need adjustment.
1 ARB solenoid does not work.
Old Aug 23, 2014 | 08:03 PM
  #619
I use a 3/8ths extension on those. Fits nice.
Old Aug 23, 2014 | 08:16 PM
  #620
Ham Bone's Avatar
Ham Bone
How tall is your truck now?
Sheesh
I didnt see any tack weld near the cotter pin?
