Another 4x4 problem
Another 4x4 problem
2000 Ram 1500 5.9 Auto Manual Shift 4x4. Last winter I started to have problems with 4x4 staying engaged in Hi. Have had 2 repair shops tell me two different things. One a new transfer case another an $800 ft axle rebuild. NOT! Reading the forum for ways to diagnose the problem, I found that I have no change in vacuum coming off the TC, when I move the shifter. Cad moves with what vacuum is there just not far enough to totally engage or disengage 4x4, i think. What do you guys think , could it be as simple as the vacuum switch on the TC? Great forum and lots of good info
Thanks
Thanks
had the same issue awhile back. found out it was the steel vacuum lines that go from the transmission cross member, to the frame rail for the vacuum lines for the cad unit.
just get a 25' roll of coated brake line, remove old steel vacuum lines, and measure them. cut new brake line, bend line in the shape of the original, and re install. not hard to do, and take maybe 10 minutes.
read zman's link above to understand the vacuum and the cad engagement.
decide whether your problem is the t-case jumping out of gear, or the axle engage/disconnect not holding.
put the truck up on 4 jack stands where you can safely operate it. test the 2wd and 4wd engagement.
open up the cad and test the vac shift motor moving the fork back and forth. test the collar sliding over the inner axle to engage. check for burrs on collar or axle splines that might prevent it sliding properly. check bushings for play and axle alignment problems.
Trending Topics
Thanks Guys
Thanks for the advice. I have some vacum on one of the lines from the transfer case but not the other. The cad does move but it seems like its slow and may not be moving far enough. I will pull the cad and check the drive axles for burrs and alignment before I replace vacum lines. I dont have a vacum gauge to check this and don't want to spend the $50 on one if I dont have to. Thanks for your help and posts so far. I am really hoping this is the vac switch on the transfer case. I found one online for less than $20.
