redneck_rams 360 build thread
Old Feb 27, 2013 | 05:20 PM
  #201
redneck_ram's Avatar
redneck_ram
Do you know how to set the fuel sync? DrewA made a good post on how it's to be done right. Remflex gaskets eh, one shot deal so lets hope you never have to remove them, I would have advised you to use Gibson's header gaskets, I have now re-used mine 4 times and they still seal great. You got a great selection of tools for these trucks happen there bud good for you, no more payed for shop time. What make ball joint press did you get?
i got the otc 7249 ball joint press. paid 100 for it shipped to me. its brand new! cornwell tools sells these for 160+.
Old Feb 27, 2013 | 05:25 PM
  #202
merc225hp's Avatar
merc225hp
That'a a great deal on a very good tool. If you go to use it to change out cross-joints be careful it will bend things with ez before you know it's bent.
Old Feb 27, 2013 | 05:47 PM
  #203
gdstock's Avatar
gdstock
Originally Posted by redneck_ram
snap on scanner, hid's, and ball joint press arrived today!
every manual i would have needed was included with the scanner! just need to figure out what edition the troubleshooter manual is. gotta get the newest one for my year truck.
If you got the Troubleshooter Cartridge, it is like a manual on a cartridge!
Old Feb 27, 2013 | 07:26 PM
  #204
redneck_ram
the cartridge is good thru 97 so hopefully itll work.
Old Feb 28, 2013 | 09:06 PM
  #205
redneck_ram
did a little more work on the motor today... headers are not torqued down, yet.
timing cover, HB, and valve covers should be going on tomorrow.
yes, i replaced the o-rings on the injectors!
merc, there is an L-shaped block like "attachment" for the m1, what is it, and where does it go(item circled in red)?
Old Feb 28, 2013 | 09:27 PM
  #206
stewie01's Avatar
stewie01
It's so pretty, but it isn't Hemi Orange yet!
Old Feb 28, 2013 | 09:32 PM
  #207
redneck_ram
ran out of money, and there is waaaay too much grime on this block to get paint to stick to it. so ill just leave it the way it is.
Old Feb 28, 2013 | 09:39 PM
  #208
stewie01's Avatar
stewie01
It looks great in the pics. If anything you could paint the valve covers
Old Feb 28, 2013 | 09:46 PM
  #209
QuadCabLuv's Avatar
QuadCabLuv
So im looking at this cam set to go with my EQ heads and M1. Do yall think this is a good match? I want to keep my low end power.
Summit Racing Part Number: CCA-CL20-309-4
UPC: 036584071730
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-5,800
Intake Duration at 050 inch Lift: 222
Exhaust Duration at 050 inch Lift: 226
Duration at 050 inch Lift: 222 int./226 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 276
Advertised Duration: 268 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.464 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.464 in.
Valve Lift with Factory Rocker Arm Ratio: 0.464 int./0.464 exh.
Lobe Separation (degrees): 110
Grind Number: 268AH-10
Computer-Controlled Compatible: No
Lifters Included: Yes
Lifter Style: Hydraulic flat tappet
Old Feb 28, 2013 | 10:02 PM
  #210
redneck_ram
UPC: 036584071730
if you want low end, look up cam 20-745-9 thats the cam i have, and its good from 1k-5k, and is a extremely good torquey cam for the 360.
edit: also go with the 1.7's it will give you a total of .510 lift with that cam i mentioned.
