beginningjockey's 360 to 318 swap
Old 04-16-2013, 10:42 PM
aofarrell2's Avatar
aofarrell2
aofarrell2 is offline
Aren't they the same as the fuel line disconnects? Just a different size?
Could you have used a flare fitting, and just flared the end of the coupler pipe?
Unfortunately no, because the threads on the quick connect had special threads as well and neither my hardware store nor either of my parts stores had or could get anything to fit those threads.
And yes they are the same disconnects, just different tube sizes.
Where'd you get those spiffy adapters?
Parts supplier. I've got a commercial account. And my local hardware store.
Originally Posted by gdstock
For a professional weld that kind of looks like doodoo.....
LOL he used a MIG so the slag has to be brushed off yet... Hence the look. He's been welding for at least 20+yrs. so I trust him entirely. He's also got the biggest welding shop in town.
  #22
Old 04-16-2013, 11:06 PM
gdstock's Avatar
gdstock
gdstock is offline
He COULD have gotten it straighter! Knock off slag and double check for pinholes. Don't want that thing leaking!
  #23
Old 04-16-2013, 11:29 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
so he mig welded it and you got slag to clean off it? don't think i have ever had to clean slag off stuff i mig welded. only had to clean slag off the stuff i flux core or stick welded.
  #24
Old 04-16-2013, 11:39 PM
gdstock's Avatar
gdstock
gdstock is offline
No slag on TIG. Also flux core and some gas MIG has slag.
  #25
Old 04-17-2013, 12:00 AM
snowboundrmk's Avatar
snowboundrmk
snowboundrmk is offline
Got a part number for that regulator?
  #26
Old 04-17-2013, 09:31 AM
aofarrell2's Avatar
aofarrell2
Could have. I'm not concerned about it though.
Slag is common on straight steel welding with shielded MIG.
Correct.
Part number for the regulator is 12-704.
Part number for the quick connect fitting I used is 640930.
Both were ordered from Summit Racing.
  #27
Old 04-25-2013, 06:16 PM
snowboundrmk
Shouldn't there be a return line on the regulator? It doesn't make sense to me how you have it set up. Sorry if this is a dumb question I don't know much about fuel systems.
  #28
Old 04-25-2013, 08:24 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,270 Likes on 3,017 Posts
They can go both ways. On the stock EFI fuel system, there is no return line either..... Running from high to such low pressure though, I think a return style system may have been a better idea.
  #29
Old 04-25-2013, 10:05 PM
snowboundrmk
But where does the extra fuel go since he just has a spot for the fuel to go in from the pump and a spot to send it to go to the motor. The stock regulator drains the extra fuel out the bottom around where the fuel goes in.
  #30
Old 04-25-2013, 10:29 PM
gdstock's Avatar
gdstock
gdstock is offline
Slag is common on straight steel welding with shielded MIG.....
Funny, my flux cored MIG leaves the slag, but my Argon/CO2 shielded MIG does not...So I disagree that it is common.....
Quick Reply: beginningjockey's 360 to 318 swap
