Dana 60 Swap!
Oct 26, 2013 | 12:31 PM
^^^ The 60 has four bolts but yep you are right, 3lb hammer nope bigger 10lbs. The 44 are much ezer to do then the 60's those bolts are in the knuckle much deeper, hence the extension and the socket.
Oct 26, 2013 | 12:40 PM
Oh the backside, that makes much more sense
Edit: I just used a 3 jaw puller. It came right off
Oct 26, 2013 | 02:35 PM
Quote:
Originally Posted by
Ham Bone
Lucky......
Oct 26, 2013 | 04:47 PM
Still fighting the other side...
Oct 26, 2013 | 08:22 PM
Alot of whining going on for these axles. :P
Making progress is always a good thing!
Oct 26, 2013 | 08:46 PM
Wh1t3NuKle
It's frustrating! But worth it. After I get the front done and painted the rear will be a breeze, then it's buy parts and put them in!
Oct 27, 2013 | 10:14 AM
Oct 27, 2013 | 11:15 AM
I can't get the lower ball joint off. How is it supposed to press out?
And no I haven't gotten to it yet today
Oct 27, 2013 | 11:27 AM
It gets pressed up. Meaning it goes towards the knuckle. FSM page 2-10.
Do you have a Harbor Freight near you? You can get their BJ press and use it? I'm assuming you don't have a press....?
You must be having hard time keeping the axle from moving too?
Oct 27, 2013 | 11:34 AM
Upwards? So toward the upper ball joint?
I actually have a press, borrowed from the shop at the dealership dad works at
