Dana 60 Swap!
Old Oct 27, 2013 | 11:40 AM
  #131
Wh1t3NuKle's Avatar
Wh1t3NuKle
Edit: BJ is pressed down. My misinterpretation of the figure in the FSM.
No.
Ok good.
I had to put an extension pipe on mine. You also might try the double hammer trick, if you have not already to break the seal.
Put eye protection on!! You place hammer 1 on side of the knuckle seat. You take hammer 2 and smack hammer 1. Repeat this going around the seat.
Then get your press on and umpf that **** out. Getting the leverage is the trick if your impact gun is not up to it.
Old Oct 27, 2013 | 11:49 AM
  #132
To remove it, I do believe it gets pressed downward....... it has the snap ring up on top there, right? (at least, it did....) Drive it out with a drift, and a big hammer.
Old Oct 27, 2013 | 11:50 AM
  #133
Ham Bone's Avatar
Ham Bone
My impact is up to it, my little compressor is not
So you smack the hammer? Dad always said not to do that
Old Oct 27, 2013 | 11:53 AM
  #134
Use the hole for the upper joint as a guide for the drift. (make sure the drift is long enough....) Then Hit It Hard with the BFG.
We can usually blow those out fairly easy with an air hammer though.
Old Oct 27, 2013 | 11:54 AM
  #135
Ham Bone's Avatar
Ham Bone
This is what I thought from research but, I don't see any physical way it could press out from the top down?
Old Oct 27, 2013 | 12:03 PM
  #136
Gotta get creative with the press. Will the screw end of the press fit up thru the hole for the upper ball joint? (done that before too....)
Old Oct 27, 2013 | 12:05 PM
  #137
Ham Bone's Avatar
Ham Bone
Tried that, it didn't budge
Old Oct 27, 2013 | 12:07 PM
  #138
Soak it with some chems for a while. Let it sit. Come back later. Work on something else for a while.
Old Oct 27, 2013 | 12:14 PM
  #139
Wh1t3NuKle's Avatar
Wh1t3NuKle
Yeah, the double hammer trick is a "at your own risk". So your Dad is using great caution. Poor hammer quality can shatter. You don't need to whack with all your might. Idea is to get the frequency of the shock to disturb the seal.
Have you considered just drilling out the BJ? Really got have the axle locked down so you can use the tried and true extension and brute strength.
I edited my post, my mistake on direction of the pressing out.
Old Oct 27, 2013 | 12:20 PM
  #140
merc225hp's Avatar
merc225hp
Edit: Post Removed I am staying out of this.
