snowboundrmk's 360 build
Old May 29, 2014 | 07:43 PM
  #171
Front passenger side I think..... Cruise control?
Old May 29, 2014 | 08:37 PM
  #172
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
I'm pretty sure my throttle body on my 1997 Ram has that port. I think it goes back around the back side of the engine, not quite sure what it goes to.
Old May 29, 2014 | 08:49 PM
  #173
snowboundrmk's Avatar
snowboundrmk
I bet that's it. I'll give it a better look tomorrow.
Old May 30, 2014 | 05:31 AM
  #174
Silconcer's Avatar
Silconcer
The hoes that goes there runs to the evap system I think.
Old May 30, 2014 | 08:39 AM
  #175
I do believe you are correct sir.
Old May 31, 2014 | 12:21 AM
  #176
snowboundrmk
I looked at it again and it does tee off to the manifold and back along the firewall so that must be right.
Old May 31, 2014 | 12:26 AM
  #177
snowboundrmk
Drilled and tapped a couple more holes for vacuum ports and the second coolant sensor. Put on plenum plate and decided to paint the intake. Intakes not bolted on yet though. I decided I want the Harland Sharp rockers so will prime it than put the intake on when I get those.
Old May 31, 2014 | 03:09 AM
  #178
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Lookin Dang Good Snow I like how it is turning out.
Old May 31, 2014 | 10:38 AM
  #179
^^ Seconded! Looks great!
Old May 31, 2014 | 09:54 PM
  #180
snowboundrmk
I want to use the old school valve cover breathers. I was wondering what size to get. I measured the two holes in the grommets and one side is 1" and the other is 1/2". I read that people use 1 1/4". Do they squeeze that into the 1" hole in the grommet or do they take out the grommet? If you are suppose to take out the grommet will both valve covers have the hole for a 1 1/4" breather or will the one with a 1/2" hole in the grommet need a different size breather?
