It has arrived.
Old Oct 7, 2015 | 10:48 PM
Ugly1's Avatar
Ugly1
Default It has arrived.
Probably won't install until the weekend. I've never purchased a cold air kit for any of my vehicles prior to this kit. The website makes some pretty strong claims about what this thing will do for me. Can't wait to find out how true the claims are!!!
Old Oct 7, 2015 | 10:49 PM
Ugly1's Avatar
Ugly1
By the way...in case it isn't obvious...this is a Ramair kit made by Ramair.
Old Oct 8, 2015 | 10:42 AM
Pics of the install please.
Old Oct 8, 2015 | 11:57 AM
Cold air intake claims are bogus...lol
Old Oct 8, 2015 | 11:08 PM
Ugly1's Avatar
Ugly1
"Cold air intake claims are bogus...lol"
You sure about that bro? There is an old Dodge Forum post where a dude got a full half second quicker on quarter mile time in his indy just by installing this kit.
Edit: To be fair. I am planning to mount the intake funnel things behind my stock grill so that will work to limit it's effectiveness. It should supply fresh air, possibly slightly pressurized at higher speeds, at the least. Not having to give up the paper filters but getting a higher flow filter on there seems like a bonus, even if a bit of overkill.
Old Oct 8, 2015 | 11:29 PM
Ugly1's Avatar
Ugly1
https://dodgeforum.com/forum/2nd-gen...amair-box.html
Pics in the link but I'll add more later.
Edit: Point of note: Don't call it Ramair whatever you do. BurningROM says it's not true ram-air. OK whatever. A half second on the quarter mile is alot more than he got with other common bolt ons I and others here have.
Old Oct 10, 2015 | 02:45 PM
Ugly1's Avatar
Ugly1
My stock plastic air intake/filter housing has a nipple molded into it for a PCV hose.
This Ram-Air filter housing doesn't have an equivalent nipple and so there is no place to route the pcv hose back into the intake as it was before.
I'm trying to be a good kid over here.
Any ideas on a getting a semi sano nipple installation for a hole drilled in this fiberglass intake/enclosure? Maybe some marine hull or fiberglass tank type hardware??
Edit: maybe something like this. http://www.grainger.com/product/GRAI...ose-Barb-6AFL4
Old Oct 10, 2015 | 03:26 PM
snowboundrmk's Avatar
snowboundrmk
Pcv valve hose should go to the intake. The one that goes to the filter is just the valve cover breather. You can just use an old school one that vents to the atmosphere.
Old Oct 10, 2015 | 04:11 PM
Ugly1's Avatar
Ugly1
You are right! Thanks bro!
Old Oct 10, 2015 | 05:16 PM
Ugly1's Avatar
Ugly1
The threaded rod only fits in a hole off centered on the throttle body which means it wont line up with the hole on the top cover. I guess I gotta bend the threaded rod?? Nothing in the instructions they sent about that. Hate to try and eyeball it.
I guess it wont need to be [perfect as long as it goes throught the hole I suppose.
