When i press on gas engine slows then revs up
Old Sep 29, 2021 | 09:05 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
What's it supposed to be? Should be a sticker under the hood that tells ya.
I believe it's .40
Old Oct 2, 2021 | 10:21 AM
Eddy67's Avatar
Eddy67
Does this look right, the marks on the harmonic balancer are lined up, shouldn't it be facing 180 degrees from what it is to line up with number one cylinder
Old Oct 2, 2021 | 10:31 AM
Keep in mind, the marks will line up twice per one revolution of the rotor. Verify that #1 is at top dead center, on the compression stroke. Looks more to me like it's point at #6 in your pic.
Old Oct 2, 2021 | 10:53 AM
Eddy67's Avatar
Eddy67
Number one is TDC not sure what stroke
Old Oct 2, 2021 | 10:54 AM
Eddy67's Avatar
Eddy67
yes it roughly between 5 and 6
Old Oct 2, 2021 | 11:02 AM
Are both valves closed on number 1? Try blowing some air into that cylinder, see what happens.
Old Oct 2, 2021 | 11:25 AM
Eddy67's Avatar
Eddy67
yes there closed, pressure built up in the cylinder
Old Oct 2, 2021 | 11:34 AM
Distributor is 180 out then.
Old Oct 2, 2021 | 11:38 AM
Eddy67's Avatar
Eddy67
Does it make sense that it would still run?
Old Oct 2, 2021 | 11:59 AM
It shouldn't. I would more expect to have it backfiring, and make all sorts of rude noises. If the engine runs, then timing is at least close.
