When i press on gas engine slows then revs up
Old Oct 4, 2021 | 02:05 PM
  #31
Eddy67's Avatar
Eddy67
I mentioned the small wires coming out of the disturber will be facing forward, that isn't correct, its only the shaft that get rotated, also I should make sure the rotor faces the temp sensor so it not a full 180, is that correct?
Old Oct 4, 2021 | 02:06 PM
  #32
With number one at TDC, the rotor should point at the little notch in the cam position sensor.
Old Oct 4, 2021 | 02:21 PM
  #33
Eddy67's Avatar
Eddy67
so where number one plug wire goes into the distributor dosnt matter as long as the rotor lines up with the mark in the cam position sensor then above in the distributor you plug in cylinder one plug wire?
Old Oct 4, 2021 | 02:28 PM
  #34
Eddy67's Avatar
Eddy67
it doesn't matter as far as how its clocked to the engine that is
Old Oct 4, 2021 | 02:43 PM
  #35
Pretty much. So long as the rotor points at the notch, you should be good. Also of note: #1 plug wire tower is marked on the distributor cap, that's important too.
Old Oct 4, 2021 | 02:45 PM
  #36
Eddy67's Avatar
Eddy67
Ok actually i think it is, i will try in the next few days and see what happens, you guys have been a great help so far. Thanks
Old Oct 11, 2021 | 11:00 AM
  #37
Eddy67's Avatar
Eddy67
So I did everything that I should have and it didn't even start, a few mild backfires but no start. Whats going on here? I put it back to the way it was and it does run, but a little ruff on idol and again there is the slight lag
Old Oct 11, 2021 | 11:12 AM
  #38
Eddy67's Avatar
Eddy67
Could it be that it just need to go for a drive now for the computer to re learn everything? it still dosn't make sense that the rotor is facing the wrong way
Old Oct 11, 2021 | 11:45 AM
  #39
I suspect that your method of finding TDC for number 1 is flawed. The backfires indicate timing is way out. As for why it runs crappy...... It may be timing related (fuel sync) or there may be some other cause.
Old Oct 11, 2021 | 11:51 AM
  #40
Eddy67's Avatar
Eddy67
Well I lined up the mark on the harmonic balancer with the "TDC" on the aluminum front engine cover that you put the timing light on, I checked to make sure number one cylinder was at the top, I blasted air into the cylinder and pressure built up inside the cylinder and a bit blew back out when I removed the rubber tube that I push up against the spark plug hole. Is there something I a doing wrong with this technique?
