E Fan and other work
Old May 25, 2012 | 12:19 AM
  #141
Wombat Ranger's Avatar
Wombat Ranger
No just above the ABS relay is the A/C relay. Oddly enough they have the same numbers... Sorry I totally didn't get what you were asking for haha.
My fan is set up that way. (primarily temp controlled, A/C override)
Google gave me this:
Pretty simple, just wire the A/C clutch wire right on to the power wire (well, according to that...)
Old May 25, 2012 | 11:42 AM
  #142
PCM controls compressor via pin 85 on the A/C relay. (grounds it to power compressor) Circuit is powered when A/C request is hot.... (that circuit runs thru the high/low pressure switches.)
Compressor circuit is always grounded....... so, trying to grab a relay ground there would have the fans running all the time. Could use the compressor circuit to POWER the relay though.....
Old May 25, 2012 | 07:19 PM
  #143
gdstock's Avatar
gdstock
Not sure what I will do to Ram over 3 day weekend...and not sure how much I will have to work on work....
But I am soaking these just in case. Was planning to wait until I decided on valve covers.... (oil and green zinc stuff makes a weird mixture...)
Old May 27, 2012 | 12:19 AM
  #144
gdstock's Avatar
gdstock
While I was finishing interior last weekend, I discovered something...else that doen't work..Just got a chance to pull wiring diagrams and look for it.
There is a darn light in the cup holder and ash tray! They don't work, but they are there. They both tie to Connector #5 - wherever the heck that is located. But the light in the radio works and it is on the same connector and all fused by a 5 amp fuse in a junction block (I suppose on send of dash on driver side).
I am going to check the fuse tomorrow as the wiring was pretty jacked by pervious ownere installing aftermarket radio and reinstalling OEM before I got it. Cleaned it up before installing radio, but aftremarket unit may not be illuminating radio from same wire.
Also have to figure a way to mount the broken glove box light. Cheap plastic....grrrr....
But as I look and see that this fuse is fed from the headlight switch. When I had my dash apart, I checked the headlight switch very closely based on references here on DF.
Old May 27, 2012 | 10:33 AM
  #145
EndIsNear's Avatar
EndIsNear
You could, if you wanted, get a white LED strip that's adhesive on the back and just wire it into the switch. Just a thought...
Old May 27, 2012 | 12:23 PM
  #146
Wh1t3NuKle's Avatar
Wh1t3NuKle
And Wh1t3NuKle, I am ecstatic about the e-fan. I watch temp now just to see how it stays soncstant, and in traffic when it starts to go up, seeing how fast it comes back down. I have not installe dthe status indicator yet. Can't decide where to put it. May put it on gauge pod on A Pillar.
Mine doesn't migrate as much as yours. I suspect b/c of the thermostat differences. So far mine has topped out (based on cluster gauge) at like 207*F as best I can figure. Me neither about the status LED. lol I will this week though. Just need the gumption to feed the wire into the grommet.
Old May 27, 2012 | 12:48 PM
  #147
gdstock's Avatar
gdstock
I have the wires for status on terminal strip on firewall. Brown wire, left end of block. My concern is damn cheap plastic. Won't get but one shot, and hope it does not crack up. I still have not decided where.
Old May 28, 2012 | 02:37 PM
  #148
gdstock's Avatar
gdstock
So today is the day to install my HS Rockers.
Before the work begins:
Valve covers – not as bad under there as I was afraid they would be:
OEM Rocker:
HS Rocker – there were no instructions. Do I have this correct? I really did not see any other way the spool shaped piece could go.
And the mystery of oil on bottom of engine is solved…..both valve covers appear to be leaking.
Old May 28, 2012 | 03:34 PM
  #149
Yep, you have that correct.
Bad gaskets... how much oil were you going thru?
Yep. I'm jealous.
Old May 28, 2012 | 03:36 PM
  #150
Wombat Ranger
Those are so pretty.
