Trans Check Valve Delete
Old Sep 15, 2009 | 01:28 AM
  #61
xray99's Avatar
xray99
Never had any takeoff issues since I deleted ,,, In fact, I'm trying to get myself out of the habit of gearing up and going as soon as I start, thinking I should at least allow a few seconds for the lube process to begin.
Old Sep 15, 2009 | 07:35 AM
  #62
aim4squirrels's Avatar
aim4squirrels
You should always wait a few seconds for the lube process to begin...
Old Sep 15, 2009 | 07:41 AM
  #63
xray99's Avatar
xray99
Thats what she said !
Old Sep 15, 2009 | 08:14 AM
  #64
97black_ram's Avatar
97black_ram
Originally Posted by Sheriff420
i only have to have it in neutral for about 10 seconds to avoid the sluggish takeoff but it doesn't seem right.
does anyone else have this issue?
After I added my external cooler and removed the check valve I have to run it in neutral just like you for a few seconds and then go.
The check valve kept the line full of fluid and partial pressure so you can start up the truck and go. I personally don't think its a good idea to to jump in the truck and take off right away in the morning anyways.
Old Sep 15, 2009 | 09:31 AM
  #65
Sheriff420's Avatar
Sheriff420
what made me think to drop it in neutral is that the 46re doesn't pump tranny fluid in park. i've always waited about 15-30 seconds before taking off anyway so dropping it in neutral isn't a problem.
Old Sep 15, 2009 | 02:03 PM
  #66
xray99's Avatar
xray99
I wonder how it can be explained that some like me can take off as soon as it starts if they wish, and others can't ?
Old Sep 15, 2009 | 04:38 PM
  #67
Sheriff420's Avatar
Sheriff420
maybe the coolers lines are backwards?
Old Sep 15, 2009 | 05:29 PM
  #68
xray99's Avatar
xray99
Don't see how that is possible, I replaced the section with the check valve as per DIY details on page 1.
Old Sep 15, 2009 | 06:27 PM
  #69
Sheriff420's Avatar
Sheriff420
i meant the lines could be crossed on my tranny cooler, my tranny rebuilder installed it and he overlooked a couple things so i wouldn't be surprised if he crossed the lines.
Old Sep 26, 2009 | 11:21 PM
  #70
Keith_izzle's Avatar
Keith_izzle
So i did the check valve delete and filter install this weekend. The bottom fitting transmission line fitting on the radiator broke off when I took off the old line, (Yes i used the qd tool). It had worn away along the edge where the old quick disconnect sat. I am looking to see if anyone has a part number or source for it bedsides a junkyard. Napa and shucks couldnt find it. I circled the part below. Sorry Aim4squirrels for stealing your pic.
