Tranny makes noise in gear
I have a 95 dodge ram 3500 with a 360 and an automatic transmission. It has been making a whining sound when I put it in drive and reverse, but dosn't do it in park. I also have fault code #37. And I dont think the transmission is shifting into O/D because it seems to be running about 3500 rpms at 65mph and when i push th O/D off button nothing happens, no light and no down shift. Thanks
what you're saying is backwards. normally the transmission always has o/d engaged UNLESS you push the button which then and only then will o/d be disengaged.
as far as the code...heres the website i use for my fault codes...
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
thats for OBDI systems, i figured you have OBDI since yours is a '95.
edit: my o/d button is screwy too. i usually end up having to push it consecutive times for a bit to get it to work, then after a while, it works first try.
Trending Topics
