Making my own plenum plate
Old Feb 19, 2010 | 12:06 AM
  #51
PurplDodge's Avatar
PurplDodge
I'm gonna use a plenum gasket from Autozone as my template.
Old Feb 19, 2010 | 12:33 AM
  #52
PurplDodge's Avatar
PurplDodge
Originally Posted by J415
Hey purpl, I think you've got another money maker on your hands. Once you get yours all done, how much would you charge me for one of them there things?
I'm gonna be makin' a livin' off this aluminum crap for these trucks! You want me to send the gauge holder with the plenum?
Old Feb 19, 2010 | 12:47 AM
  #53
J415's Avatar
J415
Nah, I'm good to go with just the belly pan...instead of using a gasket as a template, why not go to the bone yard and use the actual plenum. It's easier to trace and more accurate. Plus it's only a couple of dollars.
Old Feb 19, 2010 | 06:50 PM
  #54
redheadhunter21's Avatar
redheadhunter21
would a 3/8 sheet work or would it be too thick
Old Feb 20, 2010 | 12:34 AM
  #55
DukesOfHazzard's Avatar
DukesOfHazzard
Could you just weld a plate on and be done with it?
Old Feb 20, 2010 | 02:15 AM
  #56
dakotas ram's Avatar
dakotas ram
it has been pondered before, but gotta be careful to not warp since youre close to the head mating sureface, that and cast aluminum is supposed to be tough to weld
Old Feb 20, 2010 | 02:18 AM
  #57
dakotas ram
Purp- you should get enuff to mnake one of these
Old Feb 20, 2010 | 02:30 AM
  #58
Weldor's Avatar
Weldor
Cast aluminum isn't for a novice welder to attempt in their backyard. In fact I wouldn't touch cast anything if I had the choice not to, theres a lot of prep work and heat treatment involved if you want a good result, but hell if you've got the time and energy go for it. I'd rather just bolt one on and be done in 5 minutes.
Old Feb 20, 2010 | 10:36 AM
  #59
DukesOfHazzard
dak wtf is that? Attached to the plenum plate. As welding goes i know you can mess it up pretty good and would need to be pressure tested afterwards and if the welds crack or whatnot, what was the whole design reason of the plenum in the first place (refering to chrysler , not dak's )
Old Feb 20, 2010 | 11:19 AM
  #60
dakotas ram
that is a turtle/divider....not mine....its supposed to help direct airflow and take up some plenum space
