MonteC's Transmission Corner (For Info Only)
Old Apr 19, 2010 | 07:59 AM
  #131
Silver_Dodge's Avatar
Silver_Dodge
What happened to this thread? It's only 8 posts long suddenly. Where did all the others go?
Old Apr 19, 2010 | 08:07 AM
  #132
95RAM360's Avatar
95RAM360
JasonW said he would clear up this thread regularly to keep it organized
Old Apr 19, 2010 | 08:17 AM
  #133
ghost4321's Avatar
ghost4321
https://dodgeforum.com/forum/2nd-gen...pril-18-a.html
Old Apr 19, 2010 | 11:52 AM
  #134
jasonw's Avatar
jasonw
Site Moderator
1st Week
2nd Week
We are now on week 3.
Old Apr 19, 2010 | 12:53 PM
  #135
aim4squirrels's Avatar
aim4squirrels
Oops, DP
Old Apr 19, 2010 | 12:54 PM
  #136
aim4squirrels
Might be a bit of a pain but I think it should remain all one thread and just delete any bickering, OT comments or repeat questions. By cutting each week loose down the board MonteC may get pummeled with the same question over and over.
Old Apr 19, 2010 | 01:01 PM
  #137
yakkier's Avatar
yakkier
Agreed.
Now to my question, i know a little bit about trans but im just curious as to what might be causing this.
Every now and then when i go from park to drive it will hammer shift into drive, almost jerk the **** out of you but it doesnt always do it and most of the time it does it im on an unlevel incline with the front of the truck pointing down the slope.
I know all trans do it to a certain extent but it shouldnt give you whiplash.
Iv changed the fluid and filter also, but im going to be changing the filter again soon because when i changed it the time awhile back it was full of sludge and i doubt the PO ever changed it regularly so im going to change it again and see if it just had so much crap in the torque converter that it just filled the filter up again.
Im also thinking it might have something to do with my spiking RPM's when i first start the truck, when i turn the truck on it will hit around a grand and stay there untill i put it into drive then once it levels out it will sit at around 700 rpms and hold steady.
Sorry for the book but i just want to cover all the bases and let you know what i'v already done
Old Apr 19, 2010 | 01:28 PM
  #138
ster36's Avatar
ster36
Default 1999 dodge cummins 2500 tranny problem
Dear Sir,
I have a 1999 dodge turbo diesel with 140000 miles been a great truck no problems until about a month ago I got a chk engine light on pulled the codes and got a crankshaft position sensor circuit A out of value. I did not have time or a place to change it as I was moving. Sometimes the light would not come on when I started the truck and have not had any problems with the truck. About a week ago the truck would not shift to over drive unless I let off the fuel pedal that was Monday. I noticed the transmission would shift when the engine got warm, by Friday it will shift the first two gears and nothing else. I changed the filter and fluid but no help. Question can the crankshaft position sensor cause this problem? Is this in limp mode? What else could it be? Any help would be helpful this is the only vehicle we have and my wife commutes fifthteen miles each way and bus is a long trip.
Thank you
Sterling Davis\ sdavis3628@yahoo.com
Occupation former heavy equipment tech qualified in cat, Cummins heavy mining applications
Old Apr 19, 2010 | 09:30 PM
  #139
MonteC's Avatar
MonteC
Originally Posted by mxztnt_6
my truck is a 99 Dakota 4x4 5.2L w/ 44re trans. and when its cold outside and the truck has been off overnight/ throughout the work day my truck will not shift to third gear, 1-2 shift is solid but it will rev up to about 3k rpm then pull out of gear into a false neutral. Any Idea what this could be???
Thanks,
tnt_6
either the 1-2 band is not adjusted properly or the direct clutches are going south. I would start with changing fluid filter and doing a band adjustment.
Old Apr 19, 2010 | 09:37 PM
  #140
MonteC's Avatar
MonteC
Originally Posted by 95RAM360
MonteC, I have heard that when you cant feel the shifts in the tranny (very smooth shifting) that its a bad sign and the clutches are wearing out. Is this true?
I just did a tranny fluid/filter change, and my shifts are damn near perfect (rebuilt 23K ago) i can hardly feel the shifts.
Shift feel is sorta subjective. Personally i feel the trans is working its best when i can feel a nice firm shift. My personal opinion and what ive seen is that soft shifts do put extra strain on the clutches. But wont cause a unit to fail.
