MonteC's Transmission Corner (For Info Only)
Old Jul 1, 2010 | 07:49 PM
  #471
MonteC's Avatar
MonteC
Originally Posted by USAFretired
Thanks MonteC. That sounds easy enough. I got the tranny out last night. I see in the manual it says "special tool" to remove bushing but I guess you can just drive it out like you said. Now to find that part # for the bushing. I have the seal on order. Thanks again.
yeah i use what is called a "bushing cutter". If you are carefull and patient a screw driver will work fine. Plus the pump body is made out of steel so it wont get buggered up as easily as an aluminum housing.
Old Jul 1, 2010 | 07:51 PM
  #472
MonteC's Avatar
MonteC
Originally Posted by CappinHoff
I found this on the TV Cable.
http://bionicdodge.com/Download/Dodg...Adjustment.pdf
Will this work for a 2000 Dodge?
That will work great for all 46/47/42/44 re-rh's
Old Jul 2, 2010 | 01:51 AM
  #473
CappinHoff's Avatar
CappinHoff
So which should I do?
1. More throttle opening = HIGHER line pressure and LATER, FIRMER shifts.
2. Less throttle opening = LOWER line pressure and EARLIER, SOFTER shifts.
3. WOT (Wide Open Throttle) = MAXIMUM line pressure and FIRM shifts at the engine redline.
Old Jul 2, 2010 | 10:11 AM
  #474
Paulietools's Avatar
Paulietools
I just picked up a 2000 Sport 2500 and the tranny seems like it has a shudder in it when the OD is active. The shudder is worse at low speeds 40-50 than it is at higher speeds. If the OD is off then the tranny seems to be fairly smooth. Any ideas on where to start looking?
Old Jul 2, 2010 | 11:15 AM
  #475
blackimpala1's Avatar
blackimpala1
Default Will not shift out of first
In the mornings my 47re will not shift, when in drive or shifting it manually. All the posts I have read say it is the speed sensor, but there is a catch, When my trans warms up to about 125*, on my gauge, then it starts to shift normal. I don’t know if the others drove theirs long enough for that to happen, takes about 10min. I can change the speed sensor but if you have any other ideas please let me know.
Floyd
Old Jul 6, 2010 | 07:36 PM
  #476
WhisperBark's Avatar
WhisperBark
Default Transmission Manuals
Hello my fellow Transmission-eers. I found a website that appears to have a wealth of information. It is www.scribd.com and you can find a lot of pdf files of service manuals. I was able to locate and download in pdf format a transmission service manual for the 46rh 518 manual <--type that in and search for it on the scribd website. Once I found it, I had to join in order to download it, but it doesn't cost anything to join and I just skipped past the magazine subscription offer. The manual has detailed instructions with pictures on how to rebuild this transmission.
This is my first transmission I am rebuilding so I need all the information that I can get. I already spent several hours reading all 48 pages of this thread so I was able to become somewhat educated. A huge Thank You goes out to MonteC for taking the time to assist us Shade Tree Mechanics. Also, I want to thank everyone else on this thread for their questions and answers. It's nice to be a part of a community that helps one another.
Old Jul 6, 2010 | 07:40 PM
  #477
WhisperBark
Default Link to 46rh manual
Here is a direct link to the manual. I hope this link works.
http://www.scribd.com/doc/29442059/228727-Dodge-Trucks-TechTran-A500-42RH-A518-46RH-A618-47RH-Service-Manual
Old Jul 6, 2010 | 09:21 PM
  #478
mpatrick19's Avatar
mpatrick19
Well after 2 wks. I got my truck back. After he tried everything non mechanically transmission related, he finally figured out that it was a bad valve body. I now have o/d, but the trans is shifting late, hard and feels like its falling into o/d. I figure I will try and adjust the t.v. cable and see what happens. I really don't want to take it back to him after the poor customer service I received.
Old Jul 7, 2010 | 08:38 PM
  #479
MonteC's Avatar
MonteC
Tube of shudder stop from smart blend.
Old Jul 7, 2010 | 08:40 PM
  #480
MonteC's Avatar
MonteC
Floyd
Put a scan tool on it and see what is being commanded and what the speed out puts are.
