Put on my Poormans TB today
Old 05-29-2010, 05:40 PM
GeorgiaDodge's Avatar
GeorgiaDodge
GeorgiaDodge is offline
Default Put on my Poormans TB today
just got through with the install. went fairly smooth took the longest time to clean the sensors and swap them over. while i was at it i whacked the muffler off and only running my cat, mine still had factory exhaust and i measured to exhaust and it was 3". i dont think anybody has changed it. the throttle response is alot better now and a little bit louder. if anybody wants my stock TB just PM me and ill send it out. I highly recommend this mod if you dont have the money for a fastman
Old 05-29-2010, 06:03 PM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
Did you bore it out to 52mm or just knock the flutes off the top?
Old 05-29-2010, 06:51 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Dodge Forum Moderator
The exhaust pipe at the exit behind the tire is 3", however, its not 3" all the way through.
Right before it makes the final curve to exit out the side, it expands from 2.5" to 3". From the rear of the catalytic converter to that expansion, its 2.5". There is a reducer right after the cat, as the cat is a 3" in/out.
That goes for 2000-2001 model years, and if the pipe is still factory specs.
I second Sheriff's question...
Old 05-29-2010, 07:13 PM
zje400ex's Avatar
zje400ex
zje400ex is offline
I also wonder what you did to mod the throttle body. Cut the fins and bore? I also sent you a pm
Old 05-29-2010, 08:26 PM
GeorgiaDodge
all i did was cut the airhorns off and smooth everything out on the top and clean it real good. i didnt bore it out though. i may end up boring it out a little bit , not sure yet though, i just did this cause it was a free mod just took a little time
Old 05-29-2010, 08:29 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,385 Likes on 3,125 Posts
How do folks bore it out? Just a big drill bit??? (something on the order of 2 inches??) Send it to a shop to have it done??
Old 05-29-2010, 08:37 PM
GeorgiaDodge
i would take it to a local machine shop and let them bore it out they have the right equipment to keep it centered, shouldnt cost more than 25 bucks
Old 05-29-2010, 08:40 PM
Gonna have to make some calls... I seem to have a spare throttle body sitting in the garage.
Thank You.
Old 05-29-2010, 08:51 PM
dodgeram07's Avatar
dodgeram07
dodgeram07 is offline
my buddy works at a shop and did it for free
https://dodgeforum.com/forum/2nd-gen...or-man-tb.html
Old 05-29-2010, 09:05 PM
Sheriff420's Avatar
Sheriff420
I used a milling machine to bore mine out to 1.978, Fastman TB's are 1.980 and my stock plates are too small, I had a high idle with my poorman because the plates let too much air into the TB for the IAC to compensate for. I got some 2" plates and I still need to sand them down to the right size, that's just time consuming though. I believe they need to be somewhere around 1.988 to fit correctly. but this is going for the 50mm TB bore for a 5.2l motor.
Quick Reply: Put on my Poormans TB today
